Yokohama or BF Goodrich???
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Okay, sorry for the redundant tire questions...
I have a choice of Yokohama Avid S/T, and BF Goodrich Radial T/A's. Which would you all buy if you had to choose?
The size tire I'm looking for are 245/60R15
If you buy 4 BFG tires by the end of the month, you get a free GTech Pro! Go check out their website for the details
http://www.bfgoodrichtires.com/
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
are you going just for looks and price or are you looking for a semi-performance tire? I know when I got mine, I got Yokahama A540s and the simply suck *** . I drag race and autocross, on the street, they spin like crazy with stock gears, on the track, they slide around the turns with no grip. next time Ill spend the extra money for the good tires instead of pieces of ####
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
-Heddman Headers
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
Losses
-'99 Mustang GT
-'96 Mustang Cobra
Car: 91 RS Convertible
Engine: 305 TBI
We have a full set of BFG Radial TA's on our car.
I really like them.
They are considered a harder tire compaired to Eagle type tires, but then again Eagles are more expensive.
Softer tread will give you bretter grab all around, cost you more, and you'll go through the tires quicker.
Harder tread won't give you the performance of a softer tire, but is cheaper, and will last longer.
All of the above mainly depends on your driving style as well.
I've been using the radial TA's for over ten years and have never had a problem with them.
They do tend to let loose on wet roads if you gas it too hard from a dead stop, but then most tires will do that.
I've had a set of Yokomama's and did not like them. They wore down too quickly for me. I wound up going back to the TA's.
Plus you could get a G-Tech which is a $140 value.
Even if you don't like the G-tech you could sell it on ebay and recoup some of your money on the tires.
Either way you get a proven set of tires and a new toy or a discount if you sell the G-tech.
Can't go wrong in my book.
91 Mystic Teal RS Convertible. 305 TBI, Auto, stock.
125,000 miles and still going strong.
Only minor mods planned for the near future.
Like headers, flowmaster exhaust, some ignition mods, K&N airfilter, Perhaps a chip if needed.
Waiting for the motor to blow up so I can install a ZZ4 crate motor. Let's just hope it don't blow up too soon.
I really like them.
Car: 82 camaro SC
I had the radial TA 245/60's for a while on my 82. They looked good and lasted a quite a while(for me anyway), but the traction wasn't very good. Wal-mart has a BFG excentia GT tire that is similiar to the radial TA. Seems to have the same tread compound. If you looking for a long lasting tire.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 1989 IROC-Z
Engine: L98 350
Thanks for the info guys. I did see the G-Tech going with the four tires, but it's only for H, V, and Z rated tires I believe. I know it's not going with the S rated Radial T/A.
blackandblue02
09-10-2015 08:19 PM
