New take on old ques: Who installed a bushing kit and DIDN'T get squeaks??
Car: 1986 Firebird
Engine: 2.8 V6
I've heard it from both angles: Either someone installed the PST polygraphite rebuild kit, and got squeaks, or they installed the Energy Suspension kit, and got squeaks. Then there's others who haven't had any squeaks...
So if you've got a kit in, and you don't squeak, please put the info here!! Also, did you do anything "special" to the bushings- like a pre-lubricant (and what lube?), or having them pressed in "professionally", or pressing them in yourself, or etc! Thank you!!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
I got the Energy Suspension front end kit and a couple other items to complete it from PSC.
I didn't dissasemble the control arm bushings to lube 'em, I called PSC and they said it's not necessary, but you can do it for piece of mind. I just had them stuck in there the way they came in the box. I did everything myself at home with hand tools except for getting out the old bushings and ball joints. I had the shop where I brought my car for alignment push out the old ones and press in the new ones for $40.00.
No squeaks here. I've heard that some people have squeaks for a few days after driving in the rain.
Also, the PSC kit is a little more expensive as I'm sure you've priced them, but you get what you pay for. My friend got the PST kit for his Monte. When my package came from PSC, he saw it and came back in the house with a big woody. Everything was ES and Federal Mogul with the exception of a Moog idler arm. All nicely boxed and labeled individually , whereas all his stuff came in a big plastic bag he said.
Anyway, I didn't get squeaks.
Car: 1983 Z28
Transmission: WCT5
Moog IS Federal-Mogul. Moog is owned by Federal-Mogul now...GREAT parts
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Clem
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I installed the Energy Suspension Hyper-flex bushing kit that comes with just about everything. All it took was hand tools and a medium-sized mallet to get the old ones out and new ones in. The only squeaks I have are coming from the LCA bushings. I plan to put some bushing lube on the outsides of them sometime soon, hopefully that will kill the squeak.
Moog is owned by federal mogul.
All parts packaged were "tread saver" by so and so, a division of federal mogul.
The idler arm was the exception, it came in a moog box.
Very good parts.
Very good parts.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've got PST bushings on the front of my bird. I had the teflon lube from Summit when I put everything together. No squeaks as of yet :x-ing fingers:. I have Hotchkis LCA's w/grease fittings so no noise there either.
The mind is like a parachute, it only works when its open
I have the PST front end kit, with sway bar brackets that I made greasable since they dont do it at PST. I love the way it feels and havent had any squeaking in 10,000 miles or so. Now the rear.......
Well, I've never heard of any PST components squeaking since they are Polygraphite bushings. I've always heard that the Energy Suspension ones are the "Squeakers" since they are poly-urethane. ES states that upon installation of their bushings to use a liberal amount of lube as preventive maintenence for the squeaks.
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I took off the LCA's and lubed up the bushings (Energy Susp.). No more squeaks!
[This message has been edited by REZN8R (edited July 13, 2001).]
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Just grease them and you will have no problems.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
G-Tech times
0-60 5.2s
E.T. 13.91@104.8MPH (2300ft)
G-Tech times
0-60 5.2s
i think i have the PSC kit (its in my info) the kit w/ polygraphite bushings. i just made sure i really cleaned all the parts the bushings would come in contact w/. never had problem or any squeeks. i do lube everything every 3000mi and wipe off any access. i guess im a clean freak w/ my suspension. but a black car w/ all suspension parts powdercoated red just looks so dam good to me.
89 Trans Am
jet black w/ silver flake
suncoast ram-air hood
ASAI aerowing
centerline trigons
SLP headers, flowmaster.
Viper 550esp w/ rem start
Grant GT, all Kenwood.
BMR adj.phr, lca's, lca brackets, sfc's, jamex springs, PSC front end
89 Trans Am
ASAI aerowing
centerline trigons
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I spoke to ES they told me to lube the metal insert. then install. As some of you may have read. I drive the HE*& out of my car. No squeaks yet!
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
1992rs/ss
05-19-2020 08:02 PM
1992rs/ss
16
01-28-2016 10:58 PM
toronto formula
11-10-2015 07:17 AM
