275/50/15's on stock 7'' with 1'' drop? fit?
Anyone ever run this combo? think it would work? if not what would hit/rub? I would go narrower but I want nittos on my 15'' wheels and they only sizes I can find are 205 and 275 for 15''.
Location: Coulterville, IL...Currently on Beale AFB, CA
Alan, I have 275/50R15 drag radials on the back of mine which are slightly wider than regular 275's. I also have them on a 10in rim. You should be just fine with your combination.
Black 89 IROC...355, Solid Crower Cam, TFS heads. 12.0 @ 120.3mph with a 1.9 60ft
Car: 82 camaro SC
275/50's on 7 inch wheels aren't going to work very well. 7 inches isn't wide enough and will distort the tire resulting in decreased traction. You would probably have just as much/or more traction with 235/60's on those 7 inch wheels.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
evilstuie
01-09-2020 08:29 PM
