4th gen compatibility
My friend is parting out his 4th gen and I was wondering what parts I can use in my 3rd gen. I will probally be stealing the rear and t56 from it but can I use the coils? (If I understand correctly you can use the rears but not the front?) what else would be usefull to grab?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87' IROC
Re: 4th gen compatibility
Pretty much the whole rear suspension, except possibly the torque arm.
Also consider taking the aluminum driveshaft, if equipt.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Seats are a direct bolt-in, steering wheel, floor mats. Dash, center console but needs modded. Also the door panels can be modded to replace yours.
If taking the rear end, make sure to get the E-brake cables in tact up to the tunnel connector. If it's a post 1997 car, you'll need 16in wheels for the LS1 rear disc brakes. The wheels are bolt on, except you'll need spacers for the fronts.
There's a large thread on "4th gen compatibility" - do a search on it - there's alot I don't remember.
New2Chevy
09-28-2015 12:35 AM
