My P255's rub the wheelwell!
I got four new P255 50 R16's so I could rotate them. I thought 255's could fit in the front of F-body's without rubbing??? Only the drivers sied tire does it when I turn left. One guy said something about having the quick ratio steering box being the problem. Does anyone else have 255's on the front?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I have them as well. They do rub a little at full lock, when backing up. Nothing really serious. You should be able to see the spot they hit on the inner wheel well, look for the shiny spot..... You may be able to move stuff around to get a little more clearance.
Just as Ploegi said, check for the shiney spot. I've also had problems with 255's up front, but fortunately I had them test fitted before I bought them.
Another thing, believe it or not, many tire manufacturers have slightly different tire widths than comparable brands of the same 255 50 R16 size. It seems that the BFG 255's are slightly wider than say a Firestone SZ50 255.
I can't fit the BFG 255's up front, but the SZ50 255's fit fine. Odd...
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger" The Road Warrior
Car: 82 camaro SC
The '255' is section width, or total width of the tire(including sidewall) mounted on a specific size of wheel. Actual tread width varies from brand to brand, and even tires within the same brand vary. A little rub doesn't hurt anything.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I've seen the same thing. I have the Comp T/A ZR's and my friend has the SZ50's, both tires in the same exact size (255/50ZR16), and my tires are noticeably wider in section width, although the tread width is about the same. The SZ50 has more of a square profile to it, but it just doesn't look as beefy as the Comp T/A since it doesn't have the same overall width.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 2004 GTO
I have BFG ZR 255/55/16 on all corners. The fronts do rub at full lock and on hard,tight cornering. Other than that, no problems.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have Toyo Proxes F-1 255/50/16 on my rear and I was having problems with the wheels rubbing the inner lip of the wheel well.
It actually cut a slice of the tire off and these tires are only 2 months old.
I guess it is all my fault since I have FRONT GTA wheels all the way around and I installed lowering springs without checking the shocks to see if they were still good.
The shocks seemed good, the car didn't bounce in the rear.
I just installed some KYB Gas-a-just and when I took off the old Monroes they didn't have any pressure in them.
I hope this fixes the problem, haven't driven the car yet, I just finished cleaning myself off.
Later,
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Later,
Zepher
WS6 Trans Am
Something else I noticed. With my steering wheel at dead center, the passenger side front tire sticks out about an inch further than the driver side, which is the only one that rubs.
Do I need a spacer? Tie rods?
Sounds like you need an alignment. Unless you accidentally put one front and one rear rim up front..?
Ken
Bright red 86 Iroc-Z Choo Choo Customs Convertible
A few free mods
ChevyKen's Cars (ALL new!!)
Administrator @ ChevyWorld.net (Now in a BRAND NEW Design)
Ken
A few free mods
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
83 Crossfire TA
09-08-2015 12:06 PM
