What more suspension upgrades?
Car: 1987 Chevrolet Camaro SC
Hi there...
I am planning doing some more suspension upgrades to my 87 Camaro.
I have done quite a few so far but I still want a little bit more handling and cornering from the car. I actually feel that the car still doesn't perform as well..
Here are my mods so far:
*Eibach lowering springs.
*KYB adjustable shocks
*Spohn Sway bars (front & rear) with poly bushings.
I am now waiting on a package which includes:
* Poly bushings on: Panhard bar, Lower rear control arms, Front A-arms
* LCA relocation brackets.
This is my current mod so far. I have also done a lot of tuning and rebuilt the whole engine and tranny last winter and have also put a Auburn POSI differential carrier with 3.42 gears inside the rear axle.
I have been thinking of SFC's??..What are your recommandations on those?. I have used Spohn performance on most of my parts so far and I am VERY satisfied with that brand and will probably use them for the future also.
My back tires are currently 255/40/18 with the IROC replica chrome wheels. I know some of you are going to make comments about the tire diameter since my tires are a little on the "big" side of the total diameter but I am going to buy new rims and tires very soon so that will be fixed..
Any suggestions appreciated..
Car: 1987 Black IROC-Z (SOLD)
Re: What more suspension upgrades?
My opinion is that SFC's should be the first mod on any 3rd gen car. Also on a20yr+ old car everything that is a wear part should be replaced.
Spohn SFC's are a good choice, I installed their tube type design when they first came out. A good product with good results on my car.
I think the next thing would be the SFC's since I have heard a lot of good satisfaction on those.
I hear that you are familiar with products from Spohn. Mayby I will go for their SFC's then...
I have also been been thinking of making my own since I have access to a steel factory with all kinds of angle irons, steel plates, flat irons etc. etc.
Have anyone of you made your own SFC's???
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Also, if not done yet, would be the wonderbar (ie steering brace) - makes a huge difference in the front end. Either grab one off a JY IROC or Z28, or order the TDS one.
And a strut tower brace helps alot in the front - not as big a difference as the wonderbar, but noticeable for sure.
Sorry, forgot to mention that. I have a wonderbar also. I think that helped out a lot on the steering so I agree with you on that one.
I haven't got a strut tower brace yet but I have been thinking on getting one of those too. Would the strut tower brace make any noticeable effect??
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Yes, about the same as the wonderbar did below.
Car: 87 TA
Engine: 305 tpi
Transmission: auto
an adjustable phb would help center the rear since your car is lowered
also second sphon sfc, best mod you can make for the money!
Car: 1991 Z28
Engine: 5.7 TPI
SFCs were the second chassis mod I did- should have been the first! The thing drives like a Lexus by comparison to before. Wonderbar I did first- got the TDS one(best one on the market- the 3rd bolt hole makes it a snap to insert. You will understand when you read the instructions. 20 minutes, start to finish...). Made an incredible difference- really stiffened things up. The STB I barely noticed an improvement with, but it looks cool!
84 TA NV
09-06-2015 08:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
