255s or 245s on 16" rims?
I'm going to get new front tires and my friend told me that 245s would be better because they would stick less from the rim and give better handling. Right now I have 255s on the rear and they seem pretty good to me. Should I get 255s or 245s?
'90 Red Formula Firebird
305 TPI 5-speed
TB Bypass, Ported Plenum
UBC Sports Car Club
305 TPI 5-speed
UBC Sports Car Club
i know i'm going to catch alot of crap for this but go with whats stock honestly I would go with 235 just becayse they are cheaper. 2 cm of section width really isn't going to be noticable, most people notice a big diff because they get an all around better tire when they buy 245 or 255.
when i bought my 255/50/zr16's they were like 130 a piece which isnt that bad considering they were z rated. i believe they were interceptors and they hooked up ok. and they look alot wider than just 2 cm.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Brandon
New project-89 IROC
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have 255/50/16's from pep Boys, the Ultra Z's. They are an awsome Z rated tire for only $100 each. I am VERY happy with them.
I would not get less then 245's because that's what was stock on IROC's.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
