a-frame interchange
a-frame interchange
I need to replace the passenger side A-frame on my '84 T/A - some time ago I noticed the car was riding oddly, especially in corners so when I took it in to the garage they said my ball joint in the lower arm was loose. Apparently it's a press-fit in there and it had somehow come loose and wallowed out where the ball joint was pressed in the frame. As a short term fix I had the joint socket welded to the A-frame to keep it from shifting around in the A-frame (which cured the ride problem), but since the joint will eventually wear out I'd like to go to the salvage yard and get another arm so I can replace it along with the ball joint when the time comes.
What year(s) thirdgens can I use the A-frame from to replace the worn out one? I've got the handling package if that makes any difference...
Thanks!
Original owner - '84 T/A w/stock 305HO 5-speed
Thanks!
they should be the same from 82-92...
i have 85 A-arms on my 84...
good luck,
Chris
84 Trans Am (Stock LG4-Qjet-Auto)
('99 3rd Gen F-body National Gathering Street Stock Winner) 300,000 miles and still going
84 TransAm Vert - L69/auto/3.73 (soon to be 5spd)
85 Bird Project (vortec 350, ZZ9cam) 2880lbs
good luck,
Chris
Ah, ok- I suspected that that would be the case but wanted to make sure. I didn't think they did any redesign on the A-arms during those years but you never know.
Thanks!
Thanks!
<font face="Verdana, Arial" size="2">Originally posted by Chris 84TA:
good luck,
Chris
</font>
good luck,
Chris
</font>
junkcltr
08-02-2019 11:12 PM
