Air Bags or Air Shocks?
Old 06-02-2010 | 07:06 PM
otecnick88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
basicly within the next year i will be putting a 9" in my car with coil overs so this is a temp solution, the whole problem i have here is when i launch my tires rub my fenders, so i thought of the cheapest way to make it stop for now, my first thought would be air shocks, has anyone used them? pros? cons? dangers when put to high power levels? and second is the air bag, this seems more likely of a solution since it will auctually stiffen up the ride and i can vary right to left i know shocks can do the same but for some reason this makes more sence in my head, again same questions here, anyone use them? pros? cons? dangers? and again this is just a temp solution so i dont want to hear everyone saying just buy coil overs sonce i am in the future, thanks
Old 06-02-2010 | 07:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Air Bags or Air Shocks?
air bags, drag bags, are commonly used to help preload the springs for racing. If you are still using stock rear springs, they are pretty soft, and if they are origional, they are about beat.
forget the air shocks, unless you reinforce the upper shock mount, the shock will damage it. the air shocks will put all the load of the car on the upper mounts, which are not made for that kind of use. Similar to the coil-overs, you need a reinforcement plate for the top mount.
Old 06-02-2010 | 07:51 PM
Ok so then air shocks are out, didn't think of the stress
as for the air bags, there not the drag bags, it's two bags under there, and I have moog +1" springs under there, there used but not beat, are the regular moog factory style stiffer?
Old 06-02-2010 | 08:15 PM
//<86TA>\\'s Avatar
the rear moog iroc springs are 107lb rate, i dont know what the ones you have are.
any pics of the bag setup you are looking at?
Old 06-02-2010 | 08:28 PM
Ok so they might be softer, they felt softer than thestock gtas
here's the link
http://www.summitracing.com/parts/FIP-4103/
db057
04-28-2019 07:45 AM
83 Crossfire TA
01-03-2016 01:26 PM
SG91camaro
09-05-2015 10:27 PM
Ian Irvine
09-04-2015 08:08 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: Air Bags or Air Shocks?
