Wider rear stance
Wider rear stance
What would be the result in handling if I were to get some spacers to put on my rear wheels and say widen the stance .25 inches? Would it oversteer, understeer, etc. I think it would look a little cooler.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Cars beaten as of 01/01/01
95 Acura Legend
Lost to as of 01/01/01
95 Acura Legend
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
By widening the rear width your result would be more traction in the turns.
For straight line racing, nothing.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Widening your track .25 would be hardly noticable at all. Nor do I think widening it would help any in the corners, if it did it wouldn't be noticable, not with that small of an amount. If you want it to look cooler by widening the stance then why don't you get some 9 inch rims for the back and put some fatter meats on.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My car has a slightly wider than normal stance. I have Front GTA 16" wheels all the way around with 255/50/16 tires on the back.
Looks pretty darn good. I'll have pics on my site when I get my hands on a digi camera again.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
