How ok is patching a big hole in my floorboard?
A jack mishap while changing my oil has left a 1'x1' hole in the driver's side floorpan to the left of my brake pedal. I have a set of Spohn SFC's that I'd like welded in, but that hole is right where one needs to be welded. Can I patch that hole by welding or whatever means and feel comfortable that the SFC will have a stable mount?
I just don't want to have to shell out $200 for a new floorpan and all of the labor that includes.
1982 Camaro Z28
should be running 11's this spring...we'll see
Check the website for progress http://members.fbody.com/Pro82Z/
1982 Camaro Z28
Car: 1991 Camaro Z28
Just get a piece of sheet metal the same thickness as the floorpan and cut it the right size and have it welded in. Then just spray it with some undercoating so the welds won't rust. That's a way that I've seen it done before on an older mustang. The only floorpan repair that I've ever had an experience with myself is on my friend's Corvette so that won't really help you because it is all fiberglass.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Since you say that the hole is right where you have to weld, I assume that the hole is at or near your subframe. If so, after welding up the hole, I would plate the area @ the SFC attachment point with 1/8" plate. On my car, I used approx. 4X4"x 1/8" plate where the SFC's weld in.I heated and formed it to the contour of the place it was to be welded. This plating spreads the load out over a wider area and makes nice hard point to weld to.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
Nor Cal Mike
redformula88
10-14-2015 06:08 PM
