1LE Lateral g
1LE Lateral g
I'm 18, and I have a red 91 z28 1LE. Question, how many lateral g's can those things pull? any guesses? or has anybody done one on a g-tech?
1991 Z28 305 1LE, TES headers, 3 Chamber flowmaster, Hi-reving cam... the usual street racer
[This message has been edited by BenDoe (edited February 02, 2001).]
Damn Ben calm down already! OK most Z28's did about .89 to .90 lateral g's. I would suspect the 1LE did about .95-.99 but nowhere near or over 1. Hope this helps and be patient.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Time to crank out the accelerometer from the physics department. It all depends how
I set it up but I am pretty sure I would be pushing upper nineties and probably break
one with the slicks. Honestly, a stock 1LE does not do that much better then an IROC
in my opinion.
And chill out dude, why do you need to know so bad? braging rights? It is really easy to find out for yourself, most schools have accelerometers that will hook up to your TI-83 calc if not stand alone models.
She is not the fastest thing in a straight line but she sure will stick in the turns.
Hawian Orchid X-SCCA showroom stock 2 time national/ 1 time regional (not with me driving) champ 1LE 92 Z-28
-suspension parts include koni reds, eibach racing springs, weight-jacks, relocated control arms, and the list goes on for suspension; Port & polished TPI system sitting on top a fully blueprinted, balanced and matched race built 305; centerforce II clutch; custom 3.4 auburn rear, custom dual cat exhuast with hooker aerochamber muffler; 1LE fuel pump and gas tank; SS track baer braking system; griffin aluminum radiator; 6 point bolted roll cage with 5 point harnesses; pioneer speaker system; sparco seats, just about as light as you can get a weekly driven 3rdgen.
in my opinion.
what the hell is a TI-83. i don't think i have ever seen one of those. I have a TI-85 and a TI-92. The only think i keep the 85 arround for is the unit conversion and in case the 92 kills the bateries durring a test. Trig is just about the easiest thing there is in the world. I mean if you don't know trig you have got to be in some trouble. without trig you can't even begin to understand calculus or physics. some thing else you could do is get a 100 ft tape measure and mark out a circle in an unused parking lot. drive arround it as fast as you can with out spinning out time the average rotation. Then use good ol f=ma to get the centripidal accileration. or if you don't want to derive the FMR use v^2/r.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
90 iroc l98
mods
