"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#401
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Lowered about 3" on Ground Control Weight jacks (800lb front, 200lb rear springs), no spring insolators, KYB adjustable shocks and struts, double rod ended panhard bar.
#403
Car: 91 Formula Firebird
Engine: 5.7 TPI
#404
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
thank you. and no cutting. just sportlines and lcarb's. as well as aftermarket control arms and torque arm. but its just gonna be the sportlines and lcarb's that should put yours like that.
#405
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
I have been loving all of these stances for too long, I finally lowered my 91 Z with Eibach Sportlines,
before.
after.
before.
after.
#406
Will
#407
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Here's my car before a LOT of work. Roads in my city are complete **SH IT** After ripping off my exhaust, oil pan, transmission and more. Bottoming out on EVERY speed bump.... Nothing worse than driving around having the ladies checkin you out and then have to slow down and scrape the whole bottom end of the car across speed bumps!!
Now car looks like my signature. I'm 6'2 and my car used to sit below my waist line I'll see if I can find another picture somewhere of it.
#408
Car: 1986 Camaro
Here's another picture of my car with a new set of wheels(this is still all prior to stipping it down and rebuilding it) will try to find others prior to putting spacers in the springs to lift car up. Tires stick out past fenders so I cant tuck em or I would leave it lowered
#409
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Hotchkis 1" lowering springs
#411
Car: 1991 Camaro Z28
Engine: 350ci TPI
Axle/Gears: 4th gen rear end
What do the insulators suppose to do? If i remove them will their be any difference in drivability? And will it also change the ride height and is it recommend to remove them?
#412
The insulators provide a rubber insulation between the spring and the metal of the car. Removing these WILL lower the car some (perhaps 0.5" at most? the rear might be a bit more as it is thicker). There have been some opinions about this that removing them might cause some squeaking and potential damage to the metal or spring since without these it is "metal on metal" where the spring mets the body. There have been no evidence to prove that it damages the car or even squeaks without these, only opinions as far as I know. I wouldn't remove them as they were there "for a reason" although it could have been to make the ride less harsh, who knows the 'real' reason! I replaced mine with newer ones when I replaced the springs and they were from a 4th gen so they were thicker. The springs I installed were much stiffer than the 25 year old stock ones, so I cannot tell you if it improved ride quality with new ones vs. old ones but my old ones weren't too bad at all and they had around 190,000 miles on them!
#413
I put heater hose around it to soften the metal-metal contact, but still the weight of the car is on half the coil of the spring instead of a whole coil.
I still dont care though.
#414
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
i dont think that my car is lowered, but the previous owner did major work to it, so i dont really know. i look at other cars and see that some sit higher, so can i have your opinions on it? here is a pic
#417
Car: 1991 Camaro RS
Engine: 5.0 V8 305
Transmission: Stock Automatic
Axle/Gears: Stock...For Now
What types of rims are those? I like them.
#418
Car: 1991 Camaro RS
Engine: 5.0 V8 305
#420
Car: 1991 Camaro RS
Engine: 5.0 V8 305
#422
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
heres mine on Eibach Sportlines
#423
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Here's my '84, currently with cut stock springs, unsure how much. It's a little too, um, ****** for my taste. Will be changing that soon, but I'm not exactly sure to what yet. Possibly the Sportlines I have in my basement, possibly cut Moogs, or maybe something more custom...
One thing's for sure: for me it's function over form. It doesn't have to look perfect, but it's gotta handle everything I throw at it.
#424
Car: 91 Camaro Rs Convertible
Engine: 305 TBI
Transmission: 700R4 Auto
Axle/Gears: Stock
My slammed droptop on 22" Irocs.... "Eibach Springs"
photobucket doesn't work...!
#425
Engine: 305 TBI
Axle/Gears: Stock
#426
Engine: 305 TBI
Axle/Gears: Stock
@mac86 Nice shots of the maro, btw how do you post large pics? i tried photobucket but it doesn't work...
#427
Car: 92 Rs Bone Stock 95 z28 6speed
Engine: TBI 305
Here is mine 1 Full coil cut on all 4 corners.
#432
Engine: 305 TBI
Axle/Gears: Stock
#433
Engine: 305 TBI
Axle/Gears: Stock
Had to cut my flowmaster (2 chamber) off to change my fuel pump.
#434
Engine: 305 TBI
Axle/Gears: Stock
They had to stack a couple woods cause my car is low.... lol
#435
Engine: 305 TBI
Axle/Gears: Stock
Before
After
After
#436
Car: 84 Z28
Wow, are there even tires on those wheels?
#437
Engine: 305 TBI
Axle/Gears: Stock
#439
Cant even see the brakes... Cant imagine it stops all that well either.
Very clean car, though. Way better condition than most on TGO (including mine). And it's a convertible RS, not really meant to be a drag strip trailer queen or a road race car to begin with.
#440
Engine: 305 TBI
Axle/Gears: Stock
#441
Engine: 305 TBI
Axle/Gears: Stock
Yea, i just changed my brakes like last month its good now. thanks. I'll check your car right now
#442
Engine: 305 TBI
Axle/Gears: Stock
Bro, your car is pretty nice. Still have OEM paint too, are you going to leave the cowl hood black? you should lower it tho.
#443
I got rid of the cowl hood and I am running the factory steel hood again. I have an IROC hood that will go on the car when I finally paint it, and I'm hoping to run the 91-92 blisters.
And believe it or not, it IS lowered. I cut 1/3 of a coil off the front springs and 1/4 of a coil off the rear springs. For some reason it just sits really high. Imagine how high it was BEFORE I cut the springs, as it DID lose about 3/4 inch of ride height!
#444
Engine: 350ci TPI
Here is my 91z with eibach sportlines. I still think it will get lower once they sit in right. I have a fourth gen rearend i wanna get some vette wheels to tuck it in cuz the tires rubb a bit on really hard bumps but i like how it sits for now
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#445
Car: 1992 Z/28
Engine: 5.7 TPI
Engine: 305 TBI
Axle/Gears: Stock
My car is a glorified project car, nowhere near the standards of some of the stuff on these boards, but thank you for the compliments.
#447
Engine: 305 TBI
Axle/Gears: Stock
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#448
Engine: 305 TBI
Axle/Gears: Stock
Thinking about customizing the taillights...
#449
im goin to try to word this nicely, but how can you consider a car lowered if it has huge rims that raise it more off the ground than a stock vehicle or of equal height? doesnt it just like equal itself back out so you basically left off right where you started from?
#450
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Large wheels dont really raise a car (to a point), large tires do.
