"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#302
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
wouldnt cut FACTORY springs but the lowering springs and the moogs are okay by me.
#303
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I'll be lowering it more eventually. After messing around with my GTI for the last year its made my Camaro look like a monster truck. I need to get shorter and stiffer springs all around plus at least dropped spindles and LCARB's.
#304
Car: 1989 Camaro RS--
Engine: MPFI
This car is gorgeous! I love the color scheme, what's the name of the color @>Flrtin1? I would say the hottest car here!
#305
So your paying for a paintjob but don't want to spend $200 on actual lowering springs?? Don't cut springs. It's not the correct way and by cutting factory springs, you lower the travel of them while keeping the same spring rate, meaning your car will not have the correct spring stiffness for the height of them. It's going to constantly hit the bumpstops when your on a rough road. I paid $400 for my name brand Tokico blue shocks and spring kit.
This is incorrect. When you cut coils off of a spring you increase the spring rate. Think of a coil spring as a bar that you are trying to bend. For a given diameter and material, a longer bar is easier to bend than a shorter bar. A spring is basically a bar wound into a coil. But don't take my word for it, the math is here http://www.engineersedge.com/spring_comp_calc_k.htm
Cutting springs is perfectly acceptable as long as you do not overheat the metal which will change its rigidity. This is why you want to use a cut off wheel and work slowly and never use a torch.
You can work out your new spring rate by simply counting the reduction of active coils and doing the math.
I have done this very thing to achieve a spring rate in the low to mid 800s from moog 5664 springs.
#306
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
#307
Regardless whether it increases or decreases the spring rate, it's still wrong to me personally. For how cheap a nice set of aftermarket springs is, it's dumb to go cutting your stockers. Plus, with 25+ year old springs, I'm sure they've had better days, like back in the 80's. The better aftermarket spring companies put a lot of R&D so that you get an out of the box performance spring. Your average joe cutting them in his garage will never get the same result. If your only after looks, then by all means cut your stock springs. It's just something I personally have never done, nor would ever do.
A spring does not change its characteristics based upon what color it is, what brand name is printed on it, or how much you paid for it.
Want to stiffen up the ride and maintain factory balance? Increase the front and rear rate while maintaining the front to rear spring rate ratio. This is not hard to figure out. And here's another tidbit for you, springs do not change their rate as they age.
I have cut stock replacement springs up front. I did it in my garage. I worked out the math of what kind of spring rate front and rear I needed to achieve the kind of handling I wanted. The car is purpose built for handling. I consistently set the fastest time of the night at local time attack events. http://www.youtube.com/watch?v=nkgMInrafGQ - pay attention to the time gaps. Stock LB9. More videos on my page.
#308
Car: 1991 Camaro B4C
I can find Eibachs, but are Hotchkis and any other brands still in production?
#310
Engine: LB9, LB9
There's also a lot of companies out there like Suspension Spring Specialists (SSS) that mainly cater to racers. You have complete control over the exact spring rates, length diameter, etc. They're usually pretty cheap and you can order the springs individually as well.
#311
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
^link to SSS please
#313
http://www.flickr.com/photos/11059421@N07/5889635820/http://www.flickr.com/photos/11059421@N07/5889635820/ by http://www.flickr.com/people/11059421@N07/, on Flickr
#314
Needs more photoshopped stripes. And even more photoshopped negative camber on that solid axle rear.
#315
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
You noticed that negative camber too? I was like either he has a majorly bent axle or something is up here lol
#316
Engine: LB9, LB9
#319
Transmission: Pro-built 700R4
#320
#321
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
#322
Car: 91 GTA
Axle/Gears: 3:73
#327
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Where can a fella get drop spindles. Someone in this thread has to know.
#328
Engine: 5.7 350 TPI
racecraft makes em IIRC but idk where you'd buy em..google it
#329
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Big difference! I like it. I've been toying with the idea on my black 89 GTA as well. Did you clear coat em or just use the niteshade only?
#330
I've got 2 'maros. This one is 1986 IROC-Z, 305 TPI. Has K&N's, Flowmaster 80, Edelbrock Adjustable Pan Hard Bar, and Eibach Sportline Springs lowering front 1.5" and rear 1.6". These pics were shot the day I installed the srpings. Since then it has settled in a bit more. Drives like its on rails.
(Other 'maro is 2011 Imperial Blue Metallic 1LT/RS, MRT 2.0 axle back exhaust, Cold Air Inductions Intake, custom bumble bee dark silver metallic rallye stripes, custom gray suede interior, Billet Racing Pedals, T-Rex Billet Phantom Grille (upper & lower), T-Rex chrome rear diffuser insert trim, Defenderworx chrome gill inserts, Rockford Fosgate amps and speakers...T100-4 highs amp driving RF Power 6x9's in the rear and Diamond Audio componets in the front, 500-1BD sub amp driving RF P3412 12" sub in custom box with custom Chevy bowties in opaque acrylic backlight with blue LEDs). Planning to get Phadt suspension kit with springs (1.5" drop) and front/rear sway bars.
#331
Car: 1990 RS
Transmission: Built-700R4
#332
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
My custom 1992 RS Camaro 5.0.
#336
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
your sir, have a gorgeous car
#337
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
eibach sportlines. can't wait to see the 18's on it....next month.
#338
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
I wanna drop mine down a bit too but my tie-rod ends are really close to touching the rims as is. What do u guys suggest?
#342
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
#343
I have 2" spacers on the front. So if I lowered the car the tierod clearance would be the same as I have right now?
#344
Engine: 5.7 350 TPI
either be the same or a mm or 2 closer..
#345
No clearcoat. Just Nightshade. I sanded 'em down starting at 600 grit and ending with 2000 grit. Then put a few coats of nightshade. I'm really happy with how they came out.
#346
Car: '91 Z28
Axle/Gears: 3.23/posi
So many fine looking rides in this thread.I think i posted some of mine earlier,but here is another.
#350
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
pro-kit with no isolators....
