"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#601
1 Post
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Anything special you needed to do to run the wider rims in the rear? Those 315's look PERFECT on there... nice wider tire that balance the rear fascia of the vehicle.
#602
Car: 88 Chevy Camaro Iroc
Engine: Ls1
IMHO and preference,,, I would go 1" lower... so that top of the tires have a nominal gap to the sheemetal... PERF
#604
Engine: Ls1
Do it you wont regret it . I'm gonna buy the emergency brake cable adapter soon and long tubes 1 of these days. possibly cam the ls1
#606
Car: 92 firebird
Engine: 383
Axle/Gears: 4.11
Intrax springs and koni struts
#607
Car: 91 Camaro Rs Convertible
Engine: 305 TBI
Transmission: 700R4 Auto
Axle/Gears: Stock
91 camaro rs convertible on Eibach Sportline.
Powerstroke0178 (04-25-2022)
#610
Car: 83Z28 HO
Transmission: G Force 5 speed
#611
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
#613
Engine: LB9, LB9
Wow, those SS wheels look really good in black on that car!
#614
Car: 89 Iroc
Engine: 305TPI
Thanks. I was really hesitant to do black, I feel it has been over done, however it made a huge difference and I really like how they turned out.
#615
Looks great, love your stance. Have you measured your front and rear ground to fender lip heights? I'm soon to order weight jacks and wouldn't mind dialing in my car to your stance. It honestly sits that good in my opinion.
#617
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I live in a place that low is dangerus because the nose will hit every where.
This is my GTA know but if I lower it more I think wold be very hard to drive but if I go with air bags it will be better because I can change on the fly.
https://www.thirdgen.org/forums/pict...ictureid=40896
https://www.thirdgen.org/forums/pict...ictureid=40881
#618
#619
Car: Pontiac 89 GTA
I love white GTA's, your looks great. Are you going to buy some home alignment tools? You'll need it if your constantly going to change the ride height. The only reason that I don't do my own alignments is because my garage floor is angled to allow water to drain out. You need a flat surface. Well that and I have a decent alignment guy that does custom specs and doesn't just toe-in-go like so many others I've run into in this state.
Thanks for the compliment I love my car, well I'm not really goin to put bags on it any time soon because I don't have the money. But if I ever have the money I'll just have two setting one for driving and one for sitting. Write know I'm just going to enjoy it as it is and fix some issues that it have before thinking to modify it.
#621
Car: 89 Iroc
Engine: 305TPI
The tires are the same, 275 40 R17, so any height difference is purly an optical illusion due to light level.
#622
To answer your questions, it has been a while since I measured, but I think the fronts were right around 25" and the rear around 27". If I remember tonight I can measure them for you and let you know the exact height. I wouldn't mind it being a little higher, tired of scraping my exhaust, but the ride quality is actually really nice.
#623
^For reference, the tires on a thirdgen, assuming they're the right size, are 25.7 inches tall. You can estimate fender heights accordingly... I'd guess the IROC in question is 25.5-26", as 25" would be tucked a little.
And yeah, I totally agree... that looks killer.
#624
Car: 89 Iroc
Engine: 305TPI
Damn it, I forgot to get the measurments. I will set a reminder on my phone to get them for you tonight. I will report back ASAP.
#625
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
prokit springs.. I wouldn't go any lower, scrapes as is...
#627
Hey 88fastgta, do you mean you scrape your front air dam or are you scraping elsewhere? My car is at about your height and the only thing I've ever managed to scrape is the plastic air dam for the radiator. My car is an iroc-z though, I'm not sure if the dimensions on your gta are really that different.
Scraping the air dam isn't a problem at all, in fact they were built to take that kind of abuse. Scraping the front bumper is a different story.
#628
Car: 89 Iroc
Engine: 305TPI
NOSHOWALLGO it is 25" in the front and 26.5" in the rear. I knew it was close to those numbers I gave you above. I love the way it sits, but my exhaust hanges a little low, near the cat, and scrapes on speed bumps and such. I wish it was about an 1" higher in the front and I would be happy.
#629
I'll have to see if there's a way to modify the exhaust hangers near the cat to raise it about half an inch. I have the N10 dual cats and mine hangs pretty low just like you describe yours. It seams to only be low in that one area where the cats reside. I'm not sure whats up with that, the cat-back looks to be more tucked up from what I can tell when I'm under the car.
#630
hey i really like your camaro man can you tell me something, if i get some 15x4 inch rims for the front of my camaro will they look alright with no modifications its bone stock
#631
Cool.
my custom exhaust is routed under the transmission pan... so whenever I go over the littlest of bumps it scrapes... my alston subframe connectors have scraped on me as well.... my parents garage is on a hill and I cannot get in the driveway without taking my y pipe off.... thank god my y pipe is bolt on...
#632
well actually what im asking is my 1983 camro z28 has a complete stock rear end and i want too get a set of 15x4 inch rims for the front, if i do, will they set in to deep on a stock rear end or do they make them to set right underneath the fender?
#633
That has got to drive you nuts going over bumps! Is there not another way to run the exhaust so you have better ground clearance for lowering?
#634
Those SS wheels... I dont know what it is, but they look INCREDIBLE in gray or black, but that chrome, machined, or silver color makes them look terrible. I dont know why but a darker color just makes them look incredibly good. I love your car, great color, restrained, nice, and mean all at the same time.
#635
Car: 89 Iroc
Engine: 305TPI
#636
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Only the front is lowered for now with GC weight jacks. Need to buy more parts to do the rear. Took this Sunday morning before leaving for an autoX event. The lighting was perfect, hides all the paint flaws.
#637
Car: 1987 irocz
Engine: 5.0 305 tpi
Transmission: stock auto
Axle/Gears: stock not sure the ratio
im pretty sure my car is stock ride height when i go over the speed bumps at my work my cat scrapes it dont move when i try and move it so its not hanging
when i look under my car there is only like 2" between the ground and my cat but i have like 4 to 5" of gc for my ground affects is that normal
#638
Car: 1989 rs
Engine: 350 stage one cam
Transmission: automatic overdrive
Axle/Gears: oem
1989 formula thanks Ben from Kenton Ohio 43326
#639
Car: 89 Iroc
Engine: 305TPI
Do you hit speed bumps straight on? If so, then you will be a whole lot more likely to scrape. My car scrapes even when I hit the speed bump with zero speed and at an angle. Can be annoying.
#640
Car: 1987 irocz
Engine: 5.0 305 tpi
i would post pics but i don't have a camera
#641
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Someone took this at the SMNats last week
#644
#645
18x9.5 front, 19x10 rear
my car is not as complete as yours! lol! I can barely fit a jack under the car now.
#646
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Once I'm inside the gate, I go lower but like this for street (weight jacks & rear coil-overs)
#648
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
26" front, 26.5" rear. Debating on .25-.5 raise on rear.
#649
26" is the number I thought would look good! That's what my goal will be.. So I basically need a one inch drop from where I'm at now (roughly 27" to 27.5").. How is ground clearance at that height? And why raise the rear? 0.5" is plenty higher in the rear no?
#650
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Would not want to go lower on street. Even cross country might require 26.5, but I'm not having problems, now. The LT's are ok so far.
