"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#501
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Sorry those are so damn big if someone could help me out and resize em thatd be much appreciated.
#502
Car: Bagged 88 IROC-Z
Engine: 350 high output, 355 LT1cam,trikflo
Transmission: borg warner t-56, 6-speed swap
Axle/Gears: 4th gen 4.10 posi, 3.42limited slip
Slammed
#503
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Oh, that looks damn good.
#504
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
Those wheels and tire combo are going to make your speedo read off. The tire is taller than it should be with an 18" rim (it should be 35 height). I actually find it looks good like this because there is more tire (not as stiff) and it fills the wheel well nicely. A new speedo gear is all that is necessary probably to recalibrate the speedo if you have 700r4.
#505
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
i Guess i can finally post here. lowered my birdy back in december but it wasnt good enough. just got around to removing the iso's out back and the front ones and replacing it with some hose i had laying around. its lowered on sportlines and front coils are trimmed down 3/8ths of a coil so like 1/4 coil then half of that... its a v6 and it looks pretty dam sweet. not to low but definitely not a sky scraper haha
can is a regular coke can, its taller by like a 1/2 inch from where the lowest part of the exhaust sits
#506
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Your springs are going to settle at some point and you'll probably have rub in the fenders. Your car looks about as low as mine with about 12k on my sportlines.
#507
Springs dont really settle that much. I cut mine over a year ago, not much difference.
I wanna go lower. The driver's side sits higher for some reason. It's done that through 2 sets of springs, and the second was later cut. Driver's side still sits higher. Weird. I think one of the rear springs is too tall on that side, though. Seems the passenger front is the lowest and the driver rear is the highest. So I'm gonna cut a little more off the driver side rear spring and see what happens.
#508
My car is the same. Driver's side is slightly higher than passenger side. I think it's because when the driver gets in the car, it lowers slightly, probably a half inch or so maybe more, so then it balances out with the passenger side.
#509
Car: 1982 Z28/1986 Iroc-Z28/2005 Sierra
Engine: 355/LG4/L33
Transmission: SuperT10/T-5/4L60E
Axle/Gears: 3.73:1/3.73:1/3.73:1
Been on this forum for years and I don't think I've posted any pics of my car yet. Here's one of the week I bought it, back in 2001. I don't have any recent pics as the car has been in storage for a few years now but hopefully soon I'll have a lot of updates. Just bought a house with a nice sized garage so my baby will be coming home for a total transformation hopefully! By the way, someone was asking to see a lowered 82-84 camaro, well mine is an 82 Z28. It's on 17inch centerline spears and I'm not totally sure on what springs are on the car to lower it. After looking through some pics of the undercarriage, they're blue but the pics don't show any writing, I'll have to look next time I pull it out of storage.
#510
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
I really want to go about an inch lower in the rear but my springs are not working with me. It sits nice just not nice enough.
#511
Engine: 355/LG4/L33
sorry guys, but how do I post pics in my posts, rather than the photobucket link?
#512
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Id say leave it alone blackbmagic...dont usually like wagon wheels,but urs look great!
#514
#515
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
This is my Wife Diane with her 85 IROCZ, it's been lowered 2" new ploy bushings, I replaced the Dif with a detroit trutrack and the stock 3:42 gears. Over the winter it'll get a tubeular K member and maybe a rack and pinion. New pan hard bars and control arms.The engine will be replaced with small block 427 and a T-56 tranny
#518
I cut 1/2 coil off the front stock springs. Removed the rear isolators(replaced with 1/2in heater hose) and cut about 1/3 coil off the rear springs. Its not super low but lowered enough its noticable and I can still get over the curb going into my driveway without scraping the air dam.
#519
1 Post
Car: 92 Z28
Engine: Boosted LSX
Made that picture my new background for awhile!!
#520
Engine: LB9, LB9
Well seeing as how I raised my car back up by 2" I think I should share an updated picture. It's still about 2" lower from stock.
#521
Car: 85 Camaro
update to my car
#524
#526
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
LS1 engine (98 Corvette), along with tubular K and A-arms dropped about 150 lbs. Lighter car sat higher on the Eibach Pro Kit rears I had been using, so I went to Sportlines and thin (aftermarket) spring isolators.
The front has a Spohn coil over kit with 300 lb springs. I can set it most anywhere. I use big sway bars, Koni Reds in front and Bilsteins in the rear. The setup handles nicely.
#527
My car used to sit about 1.5-2" lower in the front than the back with the old iron 357/700R4 combo. Now it sits 3" HIGHER in the front than the back with the LS3/T56.
The factory shocks are even extended all the way upwards.
How can i lower the car back down?
I wanted to lower the car about 1.5"-2" as it was as it say high from factory.
Do i gotta get lowering springs than cut the front ones until it sits level?
#528
Engine: C5 LS1
I have some brand new Eibach Sportlines I can sell you.... I used the rears, and have coil overs on the front.... that might do the trick....
Another way is to go to coil overs and set the front anywhere you want.
#529
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
I would appreciate some advice from people who have had experience lowering their cars. I'm sick of my Firebird looking like a monster truck so I bought 1.5" lowering springs all around and new shocks all around, installed them yesterday and literally saw little to no difference at all. I believe it is because the shocks need time to break in, but even after they do I just don't think there's really gonna be a difference. I am probably gonna take them back out and cut them. My question is, how many springs should I cut to get rid of the gap in between the fender and tires evenly all around?
#531
Engine: 305 TBI
I mean I've driven it combined for probably an hour since I "lowered" it and still haven't really noticed a change.
#532
You have to realize also that your car is more than 20 years old. So the old springs and shocks were probably worn out and made the car seem lower. I have Eibach sportlines (about 2 inch drop) and they settled out in about 2500 miles. I can fit 2 fingers in between the fender and my tire.
#533
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
#534
Engine: 305 TBI
They are Eibach.
#535
1 Post
Car: 1992 Camaro
Transmission: t-5
I also have sportlines. Same thing for me. I assume there pro kit would be the same
#536
Engine: 305 TBI
Were yours 1.5, 2? Basically I wanna know if I should just go ahead and cut a spring or two off.
#537
1 Post
Car: 1992 Camaro
Transmission: t-5
If you purchased there sportlines kit it Will be bright red springs. If so wait to do any cutting. They Will settle
#539
1 Post
Car: 1992 Camaro
Transmission: t-5
look just like mine. i would wait. did you leave the rubbor isolators in? that will raise it a little also.
#540
Engine: 305 TBI
Yeah I left them in just to keep them quiet. So were yours 1.5 or 2?
#541
1 Post
Car: 1992 Camaro
Transmission: t-5
i think there 1.5's. but mine sits lower than that. i have bigger wheels and tires also.
#542
Engine: 305 TBI
You got a picture of yours now?
#543
1 Post
Car: 1992 Camaro
Transmission: t-5
I have more this one shows some of the wheel cap
#544
Engine: 305 TBI
Man that's a nice ride. I plan on getting new wheels and tires soon so maybe I should just wait for that because yours looks perfect.
#545
1 Post
Car: 1992 Camaro
Transmission: t-5
I love the stance with these springs. i also have true 3in dual exhaust. its not good being this low but i wouldnt change it for anything
#546
Engine: 305 TBI
Are your fenders flared or is that just the angle of the picture?
#547
1 Post
Car: 1992 Camaro
Transmission: t-5
nope no fender rolling or anything.
#549
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
