"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#451
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
That's exactly right. For example, 16 inch rims will use 50 height tires, whereas 17 inch rims use 45. The overall tire size should be 25.7" (whether you go bigger wheel/smaller tire or vice versa). This way it won't affect overall car height or speedometer reading.
#452
2" intrax springs
#455
Car: 1987 Camaro Z28
Engine: LB9
Not sure the details as the car came with the Eibach lowering springs but it sits pretty nice. I like it
#457
Car: 87' IROC
Wrong again quiz kid. Tires determine the outside diameter of the wheel tire combo. You can have a 14" and 20" wheel/tire combo end up with the same outside diameter with the proper tire choice.
#460
Exactly. It's not the wheel that affects this, it's the overall diameter of the outermost part of the tire. If a 16" wheel has a height of 50", then an 18" wheel must have 35 to have the same overall diameter of the outermost part of the tire, otherwise say if you had 50 height tire with an 18 inch rim then the overall diameter of the rim+tire (measuring from the outermost part of the tire) would be much greater than a 16" rim with 50 height tire.
#461
#463
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
I guess my car finally qualifies to have a picture in this thread
Pro-Kit springs, they claim a 1 inch lowering but I swear it dropped mine more like 2 inches. I didn't think to measure before doing it though.
#465
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
#467
Not sure they were done by a shop before I bought the car. I can tell you it is a lot lower than my friends 86 with stock springs. Might just be the pic angle but it looks lower in person than the red camaro in this thread.
#469
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Just installed GC weight jacks and new springs. This is all the way dropped- waiting for the springs to settle a bit more then decide on a final streetable height.
~Steven
#472
Car: 1985 Z28
Here is the whole stance. Probably could get the rears down farther by pulling the isolators and going with heater hose instead.
#473
Engine: LB9, LB9
Looking good! that's how low I run my car too. To me it's perfectly streetable. You'll never scrape if you know how to adjust your driving style.
#475
Car: 1984 Camaro Z/28
Engine: 350 SBC
is there a way to delete posts? i'm so garbage at this forum thing. all I can do is"edit" a previous post to nothing (what i almost did here)
#476
Engine: 350 SBC
Agreed! Thats exactly where the wheels should be IMO too. I'm also interested in drop, as well as rim size and the entire wheel diameter. alot of people drop their cars 2 inches, but then put 20" rims on and end up back at square one.
Anyways, Lee's got some people waiting for his specs (btw, sick pics too, really well done)
#478
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Finally got mine cleaned up with some good pics for this thread. I put in Hotchkis Lowing Springs all the way around with isolators. Properly indexed with swaybar end links tightened on a loaded suspension. I'm also running Koni Yellow Shocks and Struts, 18" BMW rims, and 245/40/18" front, 275/40/18" rear tires. It turned out to be exactly the stance I was looking for.
-cal30sniper
-cal30sniper
#479
Those wheels and tire combo are going to make your speedo read off. The tire is taller than it should be with an 18" rim (it should be 35 height). I actually find it looks good like this because there is more tire (not as stiff) and it fills the wheel well nicely. A new speedo gear is all that is necessary probably to recalibrate the speedo if you have 700r4.
#481
-cal30sniper
-cal30sniper
#485
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
An update on this that i happened to come across today so i got some current pics and looks much better!
#486
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
beautiful. go lower
also, i think a 5" hawks spoiler would set that thing off
#487
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
iv always wondered how a sport coupe would look lowered, and painted one solid color (no striping or lower accent) and that looks pretty badass. from yours the only changes i would make to make it personal to myself would be using berlinetta marker lights, and using a differant hood. but its all in taste,
#488
here's one of my favorites...different angle....
#489
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Here is mine stock iroc springs with 1 coil front and 1 coil rear trimmed,,,the body rake is kinda growing on me,,,guess maybe I could go one more coil in the rear,,,opinions?
#490
Engine: 383 hsr
^ you could use 4th gen spring isolators (about half as thick as 3rdgens) or iv seen guys on here run no spring isolators and use a piece of heater hose wrapped around the top coil.
#492
Car: 86 IROC Z
Engine: LQ4
I took one more coil out of the rears today,,,looks a ton better,,,probably leave it like it is,,,didn't know about the 4th gen isolators being thinner,,,thanks for the tip man,,,btw how the hell are you guys posting pics so big on here?
#493
Car: 86 IROC Z
Engine: LQ4
#495
Car: 1991 Camaro RS
Engine: 5.0 V8 305
Transmission: Stock Automatic
Axle/Gears: Stock...For Now
#500
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
My car on 2" dropzone springs sitting on 5th gen 20's. Enjoy.
