How to Plant the rear on launch
I recently had a posi and 3.73s installed and I took my car and my bro's 5.0 Stang out for a test drive at an industrial park where I live. I noticed that even though we both can spin all the way through first pretty easily, my brothers car launches a LOT harder, even though the tires are spinning. I also watched my brother launch and his rear seems to plant the tires into the pavement. Mine did not do this. I'm assuming this is due to the Mustang's suspension, so I'm wondering what I need to have the rear push the tires into the ground. Is there a single suspension part that is responsbile for this or do I need to do the whole rear suspension to get this "planting" effect?
Any help is appreciated,
Jason
Jason
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
www.SPOHN.com
subframes ,LCA's, torque arm, panhard bar
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Car: 82 camaro SC
LCA relocation brackets will push the tires into the pavement much harder. Good tires are a must.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Ohh>>>>>do I have the cure for you!!!!
Traction action bars from JEGS. I just asked what people thought yesterday, but I found out how they work AND THEY DO WORK. They come w/ LCA's and the bars and are fully adjustable. Cost=$200. This will solve your problems my friend.
Car: 1984 Camaro Z28
Engine: Blueprint 383
The Spohn's are less that $200.00 www.spohn.net
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Craig
hey, Chevyboy, I've read several posts here that the "traction-action" bars (Lakewood) look real nice........and that's about it. I agree with Craig in that the Spohn setup is THE way to go. I've done some shopping, and there is not a better deal to be had!! Do it right, and spank the 'stang
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Soon to be: '73 Daytona (?) Yellow Firebird 350
Check out the newest f-body site: http://www.lastgen.com/
![](https://www.thirdgen.org/messgboard/biggrin.gif)
'88 Formula 350
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
brett at BMR has great prices too.
www.bmrfabrications.com
89 Trans Am
jet black w/ silver flake
suncoast ram-air hood
ASAI aerowing
centerline trigons
SLP headers, flowmaster.
Viper 550esp w/ rem start
Grant GT, all Kenwood.
BMR adj.phr, lca's, lca brackets, sfc's, jamex springs, PSC front end
89 Trans Am
ASAI aerowing
centerline trigons
[QUOTE]Originally posted by 89BlwnRs:
[B]I recently had a posi and 3.73s installed and I took my car and my bro's 5.0 Stang out for a test drive at an industrial park where I live. I noticed that even though we both can spin all the way through first pretty easily, my brothers car launches a LOT harder, even though the tires are spinning. I also watched my brother launch and his rear seems to plant the tires into the pavement. Mine did not do this. I'm assuming this is due to the Mustang's suspension, so I'm wondering what I need to have the rear push the tires into the ground. Is there a single suspension part that is responsbile for this or do I need to do the whole rear suspension to get this "planting" effect?
Hmmm........maybe it's not so much the rear suspension you need to work with. I found it to be more rewarding if you work with the front suspension. It's got alot to do with weight transfer when it comes to hooking.
Any thing that can be taken off the front to reduce weight will help. 90/10 front struts help a great deal. And then I'd check into getting some loose springs for the front.
Before you go to drastic with the front you need to think what you want to do with the car though. If you road race and like hanging to the curves go with what they have said. But if you love to drag race loose the sway bar, swap the front struts out and relocate the battery to the back. That alone will hook the car better than lca's. But then again it depends on what you want to do with the car.
1 Post
Car: An Ol Buick
Engine: Vsick
Herb Adams Reese Bar is the best but no longer made
LCAs have nothing to do with any leverage to plant the rear tires, shortening the torque arm does that, but it lifts the rear axle when in heavy braking,
Find a Reese Bar set up, if you can
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
