my rear end gears are all chewed up, need a new rear end, options?
ok, my mechanic said my rear end is all chewed up, so he's looking in the yards for a new rear-end, i said how about 3 somethings gears, cause i have 2.73s in my iroc. well he said if i go to bigger gears in my iroc it will screw up my computer, is that true? i want to get the bigger gears, but i dont want to have to get a custom chip. also can i get posi, without messing up the computer? what other options do i have?
it won't mess up your computer at all. it will make you speedo way wrong if you dont get a drive correction gear. go to www.slpeng.com they have 4th gen take out posi units for $100 and gears for about $175. they will fit any later ( i think 87-present, check to make sure) 10 bolt rear.
they also sell the dana44 unit that i use in their closeouts section, 3.54 gears, complete bolt in unit, it's very strong. you will need to use disc brakes or find chrysler corp/jeep drum brake set up.
lata
tim
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
lata
tim
lata
tim
14.301 @ 94.39mph
Car: 2014 Camaro 2SS/1LE
Engine: 6.2L LS3
Transmission: Tremec TR6060
Axle/Gears: 3.91
I just decided to get a 91 3.42 rearend that's none locking and the put in a powertrax unit. As far as the speedo, just change the little plastic gear in the back of the tranny. Isn't that rightr gentlemen? As you can see I haven't corrected that yet. I got the rear for $100 and close to $400 on the locker... but that's how much a posi rearend was going to cost me...and I have a new locker... and can replace the gear later if I have too.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
