need suspension parts #s
I need the following part numbers if anyone has them:
Rear Springs for 1991 Z28 RPO FE2
Rear Springs for 1991 Z28 RPO 1LE
thanks in advance
thanks in advance
I have those at home, so if nobody else replies, I'll post it tonight.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Front Springs
______________________________________________________________________
67 RS w/F41 Suspension
87 Z8 w/ FE2 Suspension
Prod# Code Service #
---------------------------------------------------- (+) Highest load rate
14029399 BZY 14029399 |
14029398 BZX 14029398 |
14029397 BZW 14029398* |
14029396 CDB 14029396 |
14029395 BXY 14029396* |
14029396 BXX 14029396* (-) Lowest load rate
Rear Springs
67 RS w/F41 susp
87 Z28 w/FE2 susp
----------------------------------------------------(+) Highest load rate
10018083 NNB 10018092* |
10018092 NNM 10018092 |
10018091 NNL 10018091 |
10018093 NNN 10018091 |
10032969 NYB 10018091 (-) Lowest load rate
*When replacing old spring with new spring replace in pairs
1LE
F - CDB - 14029396
R - NNN - 10018093
*Spring code data provided by Gregg Blakely
WS6
F - CDB - 14029396
R - NNL - 10018091
*PN data provided by Larry Burd
89 IROC
F - BZW - 1402937
R - NNL - 10018091
*Spring code data from Sean Yoder
Hopefully this comes thru... My 91 Z28 came with the WS6 suspension, 36/24mm sway bars, and CDB/NNL springs. But I dont have a WS6 RPO code, as it was a Firebird thing only.
[This message has been edited by Kevin91Z (edited December 07, 2000).]
Rear Springs
67 RS w/F41 susp
87 Z28 w/FE2 susp
1LE
F - CDB - 14029396
R - NNN - 10018093
WS6
F - CDB - 14029396
R - NNL - 10018091
89 IROC
F - BZW - 1402937
R - NNL - 10018091
LT1Formula
20
11-14-2015 12:02 AM
