rattle in front end while turning or hitting bumps
Car: 88 iroc-z
Engine: 5.7 tpi
i have an 88 iroc z when you turn to the left you hear a rattle and clunk noise. hit small bumps in the road and it does the same thing. im thinking ball joints or control arm bushings. but at this point a tie rod end may even be the culprit. any help???
1 Post
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: rattle in front end while turning or hitting bumps
BTW if they are rusted on just cut them off because if you bolt them off and they are stuck chances are the bolts will just break anyway. PB blaster helps tho.
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I would also replace the mid links with poly while you're at it.
Car: 88 iroc-z
Engine: 5.7 tpi
thanks guys. will replace them next week when the paycheck comes in
Terrell351
06-13-2021 01:13 PM
db057
08-11-2015 10:11 PM
