KYB shocks, junk?
KYB shocks, junk?
I put a full set of KYB shocks and struts on my car and within 2 weeks one of my rear shocks seems to have blown, the right rear of my car is sagging 2 inches lower than the left side.
I need to replace them and want some recomendiations. what do you guys like?
Thanks Jim
Thanks Jim
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
KYBs are a good replacement strut/shock. There must have been a defect in the shock. I would return it for a replacement it has to still be covered under warranty.
Good luck!
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Good luck!
Koni's are very good
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
1987 Buick Turbo-T
I was looking into getting a set of Monroe Hi performance shocks. they are costly though 150.00 a pair. I've also considered KONI, I don't know if KONI makes rear shocks though.
KYBs are basically a decent replacement strut and shock. Any consideration given towards them being a performance strut or shock should be given up--they are not. If you want the best and price is no consideration, go with KONIs. Yes, they make a front and rear in both Red and Sport Yellow for the 3rd Generation cars. The only problem with KONI is that their ability to keep up with demand leaves a lot to be desired.
KYB are a good shock as far as I am concerned, I have them on my car and they work great, they have been there for almost two years and they feel just as good. Did you check to see that they were the same part number for the rear ones, they might have give you one for a different car or something, either way they will replace them.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I originally had KYBs. They seemed good at the time (thought the struts were too soft though), but after i put in my Bilsteins, the KYBs pale in comparison.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
Had KYB's on the front for 78,000 miles. The left front ruptured and started leaking oil. I usually hit a certain railroad track going to work pretty hard. I'm sure that was what got the left front. The KYB's on the back have 105,000 and are in decent shape. If the car makes to 250,000 it will be due tires and I'll replace the shocks/struts and springs...if it's still running.
Car: 87 IROC
Engine: 5.0
The Konis look great but very pricey$$$$
has anyone tried the Monroe Formula GP
Hi-Performance shocks? and should you replace the upper strut mounts when replacing struts?
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle
LT1Formula
10-08-2015 08:34 PM
tcflint
09-27-2015 05:58 PM
