Signs of sticking brake calipers?
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
OK - so what are the signs of sticking calipers? I replaced all the suspension on my '91 Z about 7 months ago, but didn't do any front brake work cuz everything was good to go. Now, every now and then I hear a popping sound coming from the right front wheel, but never does it unless brakes are being applied. I think it could be the strut, as well, but I doubt it. Also, I can't recall if it occurs while in a turn or not, I know it does it on a straight road stop, tho... Any and all help is appreciated. Thanks...
KAM
KAM
I had a similar popping sound from me '84 Z28 and it turned out to be the lower ball joint was loose so I just replaced it, no more problems.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Car: '91 Z28
Axle/Gears: 323's
Those parts are all new - tie rods, ball joints, etc., but not to say they could've been bad...
KAM
KAM
Car: 1986 Firebird
Engine: 2.8 V6
I'd imagine that with a sticking caliper, you wouldn't be able to spin the front wheels with the car in the air. Also, your braking would probably be unbalanced side-to-side, which would make your car swerve when you hit the stop pedal... sort of like having an internally-deteriorated front brake hose.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Night rider327
09-02-2015 04:17 AM
