Rear sway bar is in adiffrent spot on my 86 then my frinds 86?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
We both have z 28 I swapped in a 9-bolt but The sway bars are the same, his bar almost huggs the rear while mine is further away, does anyone have picks or could you exlain how yours look?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 86 Z28
My ca is lowered but would that make the sway bar stick out more? The car had a 10 bolt and mine has a 9 bolt does that make a diff? I don't think it is in wrong.
Car: 1992 RS
Transmission: A/T
The end links are connected to the body and the bushings to the rear so if you lowered the car it would fulcrum the bar and flip it up. No performance difference though....?
Car: 1986 Firebird
Engine: 2.8 V6
I'm a bit confused here...
Are you talking about the distance of the bar from the axle where the bar is straight?
Or are you talking about the distance in the spot where the sway bar curves around the center of the axle?
The first would be determined by the mounting bushings for the anti-sway bar, held on by clamps similar to that used on mufflers.
The second would be determined by ride height, as the other members here mentioned. It might also be determined by the shape of the center of the axle- I've never seen a 9 bolt in junkyards so I have no data on this.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Car: 86 Z28
I am taliking about where it crosses the the rear end housing ( the pumpkin).
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
