Front end creaks and moans...very loud, very annoying
Guest
Posts: n/a
The only thing that has changed is that I had a ball joint replaced a couple months ago. Car started popping up front (pass. side, the side where the ball joint was replaced). Now it is worse, it creaks when I turn the wheels, and still pops sometimes. Could it be that the spring has not settled correctly? What could cause this, and how can I fix?
Thanks guys
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Thanks guys
-Bill
Boston Chapter
Car: FORMULA 350
Engine: ZZ4
i had that problem that baffled me for years. finally, i ran into someone who had the same problem. try tightening the control arm bolts. mine were just a cu#thair loose but accounted for the same condition you have. hope this helps.
Terrell351
06-13-2021 01:13 PM
