suspension spring specialist
Old 01-21-2010 | 11:34 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
No weight jacks, no coil over..............don't mind taking them out and trimming a dozen times. Which 900lb coil to start with? I'm thinking 5 1/2" by 11" trimming to wind up right aroud 25" fender height. Is the 11" the best to start with? how about th 5" instead of the 5 1/2" I am using a 1Le spindle and may go with a extended ball joint. Which longer ball joint is most readily available?
Old 01-22-2010 | 10:44 PM
1988-305-tbi's Avatar
Re: suspension spring specialist
that sounds pretty close, 'm running 1000X 9" springs up front and i'm probaly ssomwhere in the middle of my weight jackers adjustment about 2-3" worth, i can imagine it would put you around 25-26"
87v6Bird
07-01-2018 05:12 PM
Thirdgen89GTA
10-19-2015 10:27 AM
Lanz06
09-14-2015 08:16 PM
SG91camaro
09-05-2015 11:27 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
