Where to find a transmission torque arm bracket?
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Mine is apparently missing and the previous owner took radiator hose clamps to secure the torque arm to the trans.
I checked it out and the bolts to the bracket are broken off in the tailshaft. So Im guessing my options are to find a new tailshaft or drill these out.
A buddy said they have a torque arm that also doesnt mount to the trans and mounts somewhere else Anyone know what he's talking about.
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Where to find a transmission torque arm bracket?
Check out UMI performance for there "tunnel mounted torque arm mount".
Nice! Looks like I can make the best out of this situation and upgrade!
Thanks for the recommendations
The kits in the link below work very nice for this issue. They offer a new transmission crossmember along with a built in torque arm mount. The torque arm mount will work with the factory torque arm as well as virtually any aftermarket transmission mounted factory style torque arm.
http://www.umiperformance.com/catalo...ex&cPath=6_178
If you have any questions please ask. Thank you!
Ryan
Ryan
1 Post
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Ryan
Ryan
Here is a link to out full assembly which includes a similar mount and torque arm- http://www.umiperformance.com/catalo...dex&cPath=6_93
We offer them for different transmissions and with or with out a drive shaft loop.
ambainb
04-25-2016 09:21 PM
Thirdgen89GTA
08-20-2015 03:11 PM
