Trans crossmemeber rusted off... possible solutions?
Car: 1990 Camaro
Engine: 305 TBI
Axle/Gears: G92 3.42
So I was driving like normal and I noticed my shifter was moving around a lot more than usual, and I heard a knocking when I let off the gas. Apparently, the spot where my trans cross member bolts to the frame rusted bad and tore loose. Has anyone encountered this before or know how to go about repairing this? Or maybe know of a good shop in the west Chicago-land area? Here's a few pictures of it:
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Trans crossmemeber rusted off... possible solutions?
have to cut that part off a doner car, or fab up a new frame section with nuts welded inside for the crossmember.
how bad is the rest of the underside as far as rust? It looks pretty serious, you may want to look into a different car
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
looks pretty bad i had a similar situation, my bolts stripped due to rust, all i did was ad a plate inside the subframe, might want to rethink if you want to keep the car, i ended up pulling up my rusty floor anyways and fixing my dented rusty subframe
Car: 1990 Camaro
Engine: 305 TBI
The rust is very localized to that area so I don't think I need to get rid of the car. I hope I can get away with just adding a plate and not have to replace the floor and subframe there. Thanks for the responses.
3rdgenparts
08-06-2015 09:03 AM
NBrehm
08-05-2015 07:57 PM
