Rear Suspension Question
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
Hey i got a 1986 Camaro and i just bought a 4th gen rear and the guy gave me lakewood lower control arm,and panhard bar and i just bought lakewood 50/50 rear shock and Pro-Kit Springs and i was wondering if i can use the panhard bar with those springs or will i need to get a adjustable Panhard bar. THank you
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Rear Suspension Question
you would have to put the springs in along with the panhard and see what happens, all cars are a little different. Just check to see if the rear is centered, or close enough. If not, you need an adjustable panhard.
not sure why they even make a non adjustable panhard bar, its seems pointless to me.
Hello
The reason for manufactures to make non adjustable pan hard bars is just for a stock replacement. But seeing how you are using the pro kit springs its going to shift the rear in the vehicle and you are going to need to get a adjustable pan hard bar to center the rear under the vehicle. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...dex&cPath=6_84
If you have any other questions feel free to ask and I will be more than glad to help!
Brad
Brad
