Loud bang out of my right side front
Theres a loud thump that comes from the right side of the front when i take flight. Could it be that a axle is out? not to familiar with suspension might it be just a bushing again need some advice.
Re: Loud bang out of my right side front
What are your shocks like? I've got the same problem and im thinking that the shocks are tired. Im thinking that the shock hits the bottom of the cylinder and makes the thud.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds like bad motor mount or tranny mount to me - I had one with this - was bad motor mount.
either the shocks or the sway have to be it my tranny sits fine. its from the right side and sounds like a thump from the shock hitting the top of the something?
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Could be broken sway link, missing, bushins, bad ball joint tierods, broken spring. Best thing you can do is jack it up and shake it and see what moves or if something is broke.
1 Post
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Check the idler arm. the slightest bit of play will make a loud thump you can feel on acceleration. just grab it and push up and down that joint should have no play at all.
Car: 1987 chevy camaro
Engine: 350 roller/edelbrock/holley carb
Axle/Gears: 3:42 open diff
get a energy suspension replacement & the problem will be gone.
Terrell351
06-13-2021 01:13 PM
