swaybars
Car: 92 rs & 89rs
Transmission: auto & t5
swaybars
i went to the junk yard and picked up a 36mm swaybar that i am going to put on my car but was wondering if i should change the rear also if so what size shuld i use . what sizes did these cars come with front and rear. i want this car to be able to corner real well . thanks in advance for any help.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: swaybars
the cars that came with the 36mm front had 24mm rears. Sometimes a slightly smaller bad would be better. Maybe grad a couple and see what works best
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: swaybars
i have the 36/24 combo and have had no issues from it. car handles great. poly bushings and endlinks make it better.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: swaybars
The rear bar will depend on your spring rate and what rear you are running. It will also depend on your driving style - azz out of neutral.
Re: swaybars
92RSRUINER, i have spohn 1" rear swaybar, it's too much swaybar for the rear, end of story, unless you have a 40mm up front or a supper light weight v-6 it's just too much bar, if you want it send me an offer, it's almost brand new
Re: swaybars
, im using a 3/4" 19mm rear bar, 24mm was too much.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: swaybars
I used to ran the 36/25 and it was way too much rear bar, at least for my car. The car was too azz happy with it. Throttle oversteer was nuts and even under no brake/no gas turns, it oversteered. I went to a 24 and the car was much more balanced. I plan to try a 23 and 21 as well at some point.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: swaybars
I'll go against the grain here. I like more rear bar than most. I have an old (80's) Adams 1 1/8" rear, and love it. 36 front, Eibach's, poly all around. STB and sub frame conns.
I had a more "balanced" set of bars before (1 1/8", 7/8"). They were dull and dry by comparison.
"One man"s meat......"
grafx
Aftermarket Product Review
12-10-2001 12:27 PM
Trevor 91 Formula
02-07-2001 02:06 PM
