Right rear of body sits low
Old 09-12-2009 | 12:08 PM
IROCBOY's Avatar
Hey guys,
The right rear of my IROC sits about one inch lower than the left side. And the right front sits about 1/2 inch lower than the left. I was hoping that it was just a spring issue but after i have replaced springs and shocks front and rear the problem persists. Is there any adjustment that I don't know about? Or should I assume the frame is twisted slightly? If so, would sub frame connecters be the fix? Or do I have bigger problems than that? The underside of the car is in very good shape and I cant find anything bent or broken.
Old 09-12-2009 | 12:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Right rear of body sits low
great manufactures tolerances
its common for the right rear to be lower, mine is about 3/8 lower. The is no adjustment in stock form.
Old 09-12-2009 | 10:29 PM
AmpegVT22's Avatar
Car: 92 RS
Axle/Gears: whatever the stock gears are
Actually, mine is like that too...there has to be SOMETHING you can do about it.
Old 09-13-2009 | 06:29 PM
IROCBOY's Avatar
Well, I think im just gonna add a thicker coil spring spacer from summit to the right rear spring. It should balance it out but I hope it doesnt add a noticeable stiffness to that side.
Old 09-13-2009 | 07:43 PM
Guest
Guest
Posts: n/a
Both front and rear lower on the right is NOT a twisted chassis.
I know the front is down 1/2" lower, and the rear is down 1" lower on the same side of the car.
My first questions is have you checked the spring isolators especially the one in the RR for fatigue or even missing?
I would start with that. A RF "OR" a RR isolator weak or missing will cause the other right height to sag because it is now taking more right side weight. 1/2" saag on a heavier front spring is more equivilant to a 1" sag on a rear spring. One or the other has a weak isolator is my strong guess.
Check that and report back, if they are all new and fine, I will give further things to start checking
Dean
Old 09-13-2009 | 07:52 PM
Guest
Guest
Posts: n/a
Opps, double post
Old 09-13-2009 | 07:53 PM
Guest
Guest
Posts: n/a
This will throw the balance of the suspension off just in the seeking of looks- bad idea.
1) You lower your X-weight. Turns left easy, turns right hard. Loose off a corner to the left, tight off a corner to the right.
2) Good under hard braking entrance left then snap loose at steady state, and loose off. Loose under hard braking corner entrance, good steady state and tight off
all in the name of looks. Check what I suggested in the post prior to this.
Dean
Old 09-13-2009 | 09:50 PM
IROCBOY's Avatar
[QUOTE=Vetruck;
Dean[/QUOTE]
Yep, Checked both of them when I replaced springs. They look fine but I'm still gonna change 'em. Maybe they didn't appear fatigued when the springs were out and they crush when springs are installed. I'm pretty sure that the prob is in right rear only and when it gets fixed right front will follow. like you said, I don't believe that it is frame fatigue being low on the same side of the car.
Old 09-27-2009 | 10:53 AM
IROCBOY's Avatar
Well, I removed both of my rear springs again. I checked the spring isolators and both appear normal. Still can't figure out why my right rear sits an inch low. Everything looks normal and new springs all around.
Old 09-27-2009 | 12:59 PM
//<86TA>\\'s Avatar
read post #2 again
this is very common
Old 09-27-2009 | 01:07 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yeah my 87 TA is the same way..i cut down my springs all evenly and it still sits higher on the drivers rear ab 1/2 to an inch...must just be the weight balance of the car from the factory.
Old 09-27-2009 | 01:18 PM
Demon355's Avatar
What if the left side is lower then the right? My drivers side sits lower
Old 09-27-2009 | 01:54 PM
IROCBOY's Avatar
Yea, I didn't ignore your post. I was just hoping that I was missing something. guess not.
Old 10-01-2009 | 12:53 AM
The B-Man's Avatar
Car: 1983 Pontiac Trans Am
Engine: Modified 350 4-Barrel
Transmission: 700R4 Stage 3 Shift Kit 3500 Stall
Axle/Gears: 3:73
I was just thinking what if the seat for the spring down on the axle is bent? I just noticed no one else mentioned it...thought I'd throw the idea out there.
Old 10-01-2009 | 07:39 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
That is how my 84 was, the suspension was just whooped. I assumed it was because there is always someone in the driver seat, not the case with the pass seat.
Old 10-01-2009 | 07:51 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ive had 3 sets of front springs in my car over the years and now a coilover kit in the front.
ive had 2 sets of rear springs.
my drivers side rear is 1" lower than the passenger side.
its always driven strait at the track, so ive never messed with it.
1992 Trans Am
05-10-2023 08:19 PM
customblackbird
08-15-2021 11:16 PM
Vintageracer
01-10-2020 06:33 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 01:50 PM
lakeffect2
08-23-2015 09:44 AM
