i installed the eibach pro kit, no drop!
Re: i installed the eibach pro kit, no drop!
They will probably settle a little bit but you might not see much depending on how old and worn out you suspesion was prior to install. It could be that your car was already sagging due to worn out suspesion. I know this sounds weird but I have heard of this happening and I have a feeling that when I do mine, I will probably be one of the few cars that goes up instead of down.
it takes 2 weeks for the springs to fully settle, i noticed a very samll drop, eneded up trimming the springs to get better results, are the fronts indexed properly?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
your most likely not noticing the drop because the origional springs were sagging. Like said above, make sure they are indexed properly, and give them a few weeks to settle. see what happens. If you are not happy with them, trim them a bit.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Mine looked higher after install, it settled a bit after a few weeks, but it's definitely not a 1" drop from where my old sagging springs were.
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I'm one of the guys that had the front raise up after installing them. The back springs did lower somewhat to even it out.
Any update? pics?
Any update? pics?
toronto formula
11-10-2015 06:17 AM
