my bolts is frozen! lol hekp me!
Car: 06 Corolla
Engine: 1zz-FE 1.93L lol
Transmission: c59
Axle/Gears: fwd ftl
So im doing new spindles because of some issues i have had along with a whole suspension/steering rebuild on the front end and tonight i pulled everything and went to pull the spindle and the bolts going through the back of the spindle and through the strut are frozen/siezed...any ideas ? help etc ?
already sledged it pried it etc etc also used tons of rust breaker spray stuffs and the damn things wont come out, getting close to tempted to just cut off the mounts on the strut since i am replacing them as well.
any help or comments are very much appreciated !
thanks
Brad
thanks
Brad
1 Post
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: my bolts is frozen! lol hekp me!
try using leverage. like get the right socket and ratchet that u need on the bolt then use a deep socket that just fits over the end of the ratchet and add a few extentions.. if the bolt breaks then it breaks like u said u were ganna replace the mounts anyway right.. at least this way u dont gatta cut anything and u might be able to get the bolts out
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
yeah tried that w/a long extension and a pipe the bolt wouldnt even budge, i do have a new bolt kit but was as you said trying to avoid cutting i may just drill out the bolts or somethin idk :-/
1 Post
Engine: ls1 soon
then i would just use a bigger pipe till they snap not much really left u can do
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
the bolts arent 'bolted' into anything was my point the spindle is not threaded, the nuts on the outside were kinda tough to get out but 200ftlbs sounds right, idk i guess ill get the torch or the cutter out tomorrow and see what i cant do
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Now I understand, I don't think we realized you already got the nuts off, but couldn't get the bolts out, am I right?
If so, try jacking up the A-arm to take pressure off the bolts.
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
Correct, nuts are off bolts are frozen (i guess it would suck a lot more if my nuts were frozen ? haha), did jack it up last night but ill try again to jack it up tonight and see if i cant sledge it out :P hopefully this is the only set of bolts this bad off and i can actually get the tubular a arms/endlinks/tierod ends/sleeves/balljoints etc on tomorrow night i will post updates and let ya know what happens to this lovely project lol
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Heat em up red hot, then put some torque on them, they'll come off....
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
yeah i havent got the torch or cutter out yet but nothing else is budging will update as soon as i get it out etc
Car: check
Engine: check
Transmission: check
You mentioned replacing both the struts and the spindles. In this case I woudn't bother with the strut to spindle bolts. Just leave them and remove the two parts together.
The four bolts, washers, and nuts need to be replaced anyway. In the later years they are TTY bolts. Not sure about the earlier stuff. Either way just get new ones (check Spohn, about $20 + ship).
RBob.
RBob.
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
Yeah so i havent got to cutting the spindle out yet but i have some more devolpments, and they are pretty negative.
The car was taken pretty bad care of evidently.
The tie rod end and bolt underneath the spindle are both frozen as well, weeee
I believe the Struts are OEM
Pretty sure im going to end up cutting the crap out etc as i stated i have new everything for the front end suspension/steering/chasis thanks for the input if anyone has anymore 411 or $.02 please feel free!!
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
