rear torsion bar help!
i have my 89 iroc on jackstands right now, and i have all bolts removed but one on the very rear of the bar, i was wondering if there was a procedure, trick, or something that can help me get it out cause it wont budge! its like rusted welded!
Re: rear torsion bar help!
ya sure do, but the bolt is on top of the bar so i can only get a socket wrench up there, or i would have no problem gettin it off. unless the bolt is not even suppose to be on there in that way. and ive put liquid wrench on it already
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
what exactly are you working on?
the sway bar or
the torque arm, the piece that goes from teh trans to the rear?
IF its the torque arm, they are very tight. There is a nut on the underside of the arm as well, put an impact gun on the nut, and a wrench on the top and bang away, it will come off.
if its the sway bar, just cut the links off and buy new ones, they are shot anyway
the sway bar or
it would be the torque arm or torsion bar, i have already got the nut off the bottom. it just the entire bolt will not budge. ive showered it with liquid wrench. btw its the bolt closest to the diff. cover. the 2nd bolt i have no problem with.
1992 Trans Am
05-10-2023 07:19 PM
ProtoMaster22
08-26-2015 07:50 AM
