Rear wheel wobbles. Maybe axel warpped
Car: 91 RS T-top
Engine: 305 tbi
Axle/Gears: 3:42 fourth gen disk brake
So its takin me longer to get my new rear than I thought. I was looking at why my rear right wheel wobbles and I dont see anything wrong. Im guessing the axel is warped. Idk. I was wondering should this have any play in it? I can wiggle it a little. The plate that holds the studs.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Rear wheel wobbles. Maybe axel warpped
it will have some play in and out, but shouldnt have any side to side. It could be a bad bearing, or the axle in bent, or the wheel is bent, ect.
Car: 91 RS T-top
Engine: 305 tbi
Well it wobbles lol. Not sure why.
http://s71.photobucket.com/albums/i1...24-09_1908.flv
looks like a bent axle.
thats not very safe, that drum could come flying off and hurt you, i didnt see a lug nut holding it on
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
odds are you only have a bent rim . swap with a different wheel , if wobble follows wheel . problem solved . good luck .
you didnt watch the video did you
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Weeping any fluid on the back side? If so, the seal and bearings are probably shot--and if they're shot the axle probably is too, especially with that wobble. For general info, you might consider the following link:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
JamesC
Car: 1986 Iroc z
Engine: 350 tpi
Well i kinda had the same problem but i found out my spider gear was cracked. i changed it. and boom problem solved! just a suggestion.
Car: 91 RS T-top
Engine: 305 tbi
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
i have a wobble too, after i burnt off the rear wheels with burnouts, they had a bubble to them, so i drove it home and changed it out, well after i changed the wheels and tires to a pair that have BRAND NEW tires and just got balanced, the car wobbles. usually not noticable under 40. it seems to be the front but someone disagreeed and said it was the back.... ideas.
1992rs/ss
05-19-2020 08:02 PM
1992rs/ss
16
01-28-2016 10:58 PM
kah992
08-19-2015 03:55 PM
