Where to buy spring isolators
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
So i think i finally attributed my squeek to my drivers side rear coil spring isolator. Only problem is i cant seem to find anyone that has them. i Dont want the OEM ones sold from dealers because i read they raise your car up, and i would like to not use heater hose because i do not want to lower my car any more than my new pro kit lowers it. Is there anyplace to buy them online or something, or is my only option to hit up the junkyard?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Where to buy spring isolators
I've had all 3 options with my Prokit, ended up with the original factory 3rd gen isolators.
Problem is with my 4th gen rear and tires, even with the fenders rolled, i rub over bumps. i dont want to go any lower and tear up my tires. I remember the rear isolators being pretty thick.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
You can always just go to a GM dealership and buy the 4th gen rear isolaters. Some say they are thicker then the 3rd gen ones, but according to my ruler they came out to be the same thickness. Unless my ruler is broken... I think the dealership I went to charged like $28 for them. I bought brand new 4th gen front spring isolators at the same time and I think to total price was around $45. I have my reciept in a pile somewhere in my room which I'm in the process of cleaning so I'll let you know if I find it. (I really need a filing cabnet or something... combining all the loose papers in my room would probably measure up to atleast 5')
The back of my car is a little high for my liking so I may try the heater hose trick. The problem is finding the time to do it.
Mike
Mike
