NEW SPRINGS,, SITS UN LEVEL
Car: 1982,Z/28
Engine: 355
Transmission: t350
Yes over the winter i picked up used control arms and put in new bushings and ball joints,,I now put in my moog iroc springs with half a coil cut off. - Car now sits lower on drivers side by about half a inch, ??-what could of happened ?? unmatched springs ?? or ??
Re: NEW SPRINGS,, SITS UN LEVEL
did u cut off the same amount on both sides? did u seat them properly? they have to be seated in the Aarm pocket correctly, and did u use the isolators on the top of the spring for the kmember? if u forgot one or one is worn more than the other it could make them uneven, same as not cutting the same off or seating them perfectly.
Car: 1982,Z/28
Engine: 355
Transmission: t350
Ill have to look to see where the springs are located as to the holes in the arms, -- POSSABLY its the springs isolator, as it didnt want to stay on top of spring, and wanted to roll off.--But i taped it on.
1 Post
Car: 89 Firebird
I had that problem before. Like a n00b I installed one of the front springs out of pocket. It can make about a One inch difference.
All I can say is after you mess with the spings and stuff measure the car.
86CamaroDan
09-29-2015 10:08 PM
Springster
09-13-2015 01:38 PM
