raising the rear end
Car: 87 Camaro
Engine: 5.7 350 TPI
does anyone know what size springs i can put on the rear of my 87 iroc to raise it up about an inch. has anyone done this to give it a more aggressive look and have pictures. i want to do this because my 17x11s are rubbing the fenders.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: raising the rear end
moog iroc replacement rear springs will raise it a lot. If its too much you can trim them down a little.
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
where did you measure to get a 28 5/8" height and also what is a fourth gen isolator? i am thinking of raising my rear for a more agressive look.
Car: 87 Camaro
Engine: 5.7 350 TPI
put in a new rear end out of a 97 camaro. i used the springs and isolators that were on the springs from the 97 camaro. i wanted the rear to be a little higher to avoid fender rubbing and the 4th gen isolator gave me about an extra inch. ill take pictures of it tomorrow. thanks to jamesc for all the help
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
