For those of you with drag skinnies up front...
1 Post
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
In either a 15x3.5 or a 15x4 inch wheel, what backspacing did you end up using? I would like to *assume* that the 3.5 rim only comes with a 1.75 BS as this would seem logical to me but I have been wrong before(and will be wrong again before I die!) What BS did you use for the 15x4? Any info would be great. Thanks!
Car: projects.......
Re: For those of you with drag skinnies up front...
You are correct on the 15x3.5, I don't think I've ever seen any options for their backspace. - Sorry, I never run a 15x4 so I cant give you anything exact there, but logic woud say that something of an even bs would keep it fiarly cleanly centered in the wheel well.
1 Post
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Ideally, you'd hold the offset constant (and close to whatever the OE offset was).
Assuming that your 3.5" wheel is an alloy wheel, 1.75" b/s translates to about -1/2" (or -13 mm) offset.
-1/2" offset in a 4" wide alloy wheel would be 2" b/s.
If the 4" wheel comes with 1.75" b/s, I wouldn't sweat the quarter inch change in offset or the half inch wider front track that would result.
Norm
Norm
gta892000
09-16-2015 12:37 AM
