UMI A-Arms for street driving?
Hey all,
I'm planning on rebuilding the rest of the front suspension which would make my suspension 100% completely new with the a-arms. I am installing MOOG Iroc replacement springs i got from summit (the same ones that Spohn sells on their site).
How are UMI A-ARMS? Do they lower the car? Are they strong enough to take street abuse and withstand big potholes? Do they improve handling? Do they make the ride alot harsher? Do they really take off 5.5lbs per pair? Are they better than stock and in what sense? What will I lose by going with UMI's rather than staying with stock?
I've seen pics and they look nice but I don't want to pay 400$ for a pretty part only! I'd like to get all these questions answered before I go ahead and order this... To Canada I would be paying 480 CAD$ plus shipping plus customs ... these things are gonna end up costing me 600$ CAD probably by the tim they get here..
-Marc
-Marc
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: UMI A-Arms for street driving?
It mean I want to know too also. just have nothing to say so thats way i wrote" ...."
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Personally, I say spend the extra cash on some good shocks or tires. You'd see more bang for buck there.
I got new Tokico blue shocks, installing new MOOG iroc replacements springs, and im getting Eagle F1 GS-D3 245/50/16 tires on all fours anyway. Just wondering if these a-arms will make any difference if I had all those things anyway..
thnx
thnx
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
How are UMI A-ARMS?
GREAT PRODUCT
NO
YES
UNSURE, But give a better "feel of the car" from the poly bushings
Full poly units will make a nice street ride.
These are lighter than stock, when swapped you will lose about/around 5.5lbs
Tubular, Lighter, Stronger, NEW
Nothing but gain. That and maybe missing the stock parts...yeah right
GREAT PRODUCT
NO
YES
There are quite a few people who have UMI parts and are involved in Street Driving, Drifting, Road Racing, AutoX.
FROM UMI'S WEBSITE....
Description
UMI Performance A-Arms are designed to offer a light weight set-up that is still capable of handling every day street abuse. This tubular set-up removes 5-1/2 lbs off the front of your vehicle while adding increased ride quality and reducing bushing deflection. These new lower A-Arms are supplied with new ball joints installed, Energy Suspension grease-able polyurethane bushings and sway bar mounting provisions. This lower A-Arm kit is designed to work with the factory springs and lowering springs. A-Arms are fabricated using 1.250” drawn over mandrel tubing, CNC machined ball joint holders and feature both MIG and TIG welding for the utmost in product strength.
Features:
- 1.250” x 0.120” Mild Steel DOM Tubing
- CNC Machined Ball Joint Cups
- New Installed Grease-able Ball Joints
- Shock Mounts are CNC Machined from 0.188” Steel Plate
- Works with Factory Springs and Lowering Springs
- Energy Suspension Grease-able Polyurethane Bushings
- Supplied Fully Assembled and Ready to Install
- Brilliant Durable Powder Coat
- Uses OEM Hardware
"What will I lose by going with UMI's rather than staying with stock?
Nothing but gain. That and maybe missing the stock parts...yeah right"
Thanks for the response! My only question was with this one... So are you saying that with the UMI a-arm i will lose steering response?
Oh and I forgot to mention in my stock a-arm right now I have new ball joints and ES polyurethane bushings.. Will there be any diff from that? My stock a-arms aren't rusted or bent or anything... Although my tire rubs when i turn the wheel all the way, maybe it's a bent a-arm?
thnx!
thnx!
Last edited by hellz_wings; 04-15-2009 at 04:23 PM. Reason: backwards explanation of part
Car: 89' IROC-Z
Engine: LO3
You won't lose anything really, except front steering response due to them being new and with poly bushings, and the extra weight."
thnx!
thnx!
Wow super nice maybe they are worth it after all... It's tempting... I have the money for it... I love having a car that handles well... Makes me feel so much more confident about going through turns and twisty roads!
I think I am going to get these in Black!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i have UMI front a-arms and i've beaten the hell out of them and no problems. they look good too
The only real benifit of them in weight reduction. The factory a-arms are plenty strong, you can have new poly bushing installed to tighten things up if you want. So i would make sure the rest of your setup is as good as you can get it before you shell out $$$ for a-arms. my
Car: 89 Formula
Axle/Gears: Borg Warner 3.45
I'd say that if your ball joints and bushings are relatively new, save your money and wait until your ball joints are worn out.
Another idea would be for you to box your front control arms. I haven't done this but it would essentially be the same principle. Making your control arms more rigid to minimize deflection. If it's primary use is street your not going to notice 5 1/2 pounds anyway. Just an idea.
I got one of the 1st sets of UMI's A arms. And put them on the car pretty quickly after I received them. I had already purchased the Spohn A arms, then UMI announced that their A arms where almost ready. So I sold the Spohn A arms and bought the UMI one's. I daily drive my Camaro, and it does see the crappy streets. And they have held up fine, not a single issue so far. Now I can't really tell you how they will affect your ride. Because I did everything at once (Struts,a arms, springs, steering linkages)
Car: 87 formula
Engine: 5.0 TPI
Hey all,
-Marc
-Marc
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
and they look really good.
have to remember that the weight you are saving is moving up and down with the suspension, so any weight reduction will improve suspension response.
I thought those were stock IROC replacement springs though?? Cutting the springs is dangerous i've heard... Also I would think that the MOOG springs raise the car a bit because the 22 year old springs must be sagging by now, I'm prepared for a litte raise in right height, as long as it sits even front and back and it's like stock..
JamesC
Car: 87 GTA
You heard wrong.....Sorta.
If some idiot tries to cut them with a simple torch, they become overheated, which changes the spring rate & they SAG.
If you cut them PROPERLY, like with a cut-off wheel & keep the heat introduced to them to a minimum, cutting is PERFECTLY safe. Or are Chip Foose/Boyd Coddington type professionals etc. wrong?
I've cut springs & raced autocross on them, with zero negative side effects. Cutting was around WAY before making custom height springs was.
Its all in HOW you cut them.
Car: 1991 RS Camaro
Lots of things are said about car parts that aren't true. You can do it yourself if you have a cut-off wheel. I would think a band saw would work too. Just be carefull not to heat them too much.
Car: 1991 RS Camaro
You'll want to cut too little instead of too much. You can always take more off, but you can't add it back. I'd start with 1/2-3/4 and then work from there. These springs are really easy to take in and out.
As for the rears I saw another IROC on the net with 3/4 of a coil cut with these springs and it looks like the car sits 100% level (height looks good too, not too low but not too high either). I think 3/4 is the magic # to cut for these springs. I will start with 3/4 and work from there and let you guys know, although I won't be doing it myself I will instruct the shop guy to cut 3/4 of a coil off.
Taking my car to the garage hopefully this weekend to get done so we'll see what happens!
Thanks guys for all the input it's very much appreciated!
-Marc
Car: 87 GTA
92 RS on 86 IROC springs.....1/2 coil cut front, 3/4 coil cut rear
245/60ZR16 tires
I wish I had cut a little more, but better safe than sorry & the the fronts aren't much fun, so I never re-cut the springs any more.
245/60ZR16 tires
i bought new spring insulators front and back and the new moog springs... I'm guessing my ride will be really high now.. the only way to tell is to install them! Someone said earlier that the rear springs aren't hard to remove/install anyway.
EDIT: BTW, members report that the new insulator from GM is actually a fourthgen piece and will jack the car even higher.
EDIT: Eventually I might cut a full coil. I'm "guessing" that will get me where I want to go--though the current set-up provides a slight rake that I kinda like.
EDIT: Humm, maybe not. I just went out for a ride. Liked it.
JamesC
http://cgi.ebay.com/ebaymotors/REAR-...ht_1623wt_1354
There's a link to the rears, and i also got the front insulators off of them too.
I didn't get mine from GM I got them from Ebay off of GMCLASSICPARTS.
Those are the 4th gen isolators
And you got ripped off too. GMCLASSICPARTS and I had it out. They used to advertise those as NOS for 3rd gens. So I ordered them, when they arrived, they were just the 4th gen ones, even more expensive then buying them at the dealership. I had to file a dispute with Paypal, and eventually did get my money back.
#43
I also tried the heater hose, but the rear sat too low. But to be honest, it was trial and error, what ended up working best for me, was the stockers.
#44
Hmm okay I think i'll keep the rear stock isolators in place. I think I will replace the fronts tho, probably worn out they look like thin peice of rubber anyway.
Thanks guys I'll try to keep the car at equal heights and i'll let you guys know what combo i did to get it (how many coils cut, using which isolators, etc.). I think alot of people would like to know a definite answer on this one.
#45
Car: 1991 RS Camaro
I don't have any of the isolators in my car, but it's so clanky it doesn't matter haha. I like the height of the front compared to the rear with them out (on the back) but I need them to run my stock 16s cause they stick out further.
#46
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
checked your bio page hellz_wings. Lotsa of good mods. The right things being done.
I would recommend keeping stock suspension geometry until you have the car dialed in with the work you have done to-date.
my .02 cents worth -- go directly to the T5/T56 swap and the big brake upgrade. Did both myself they are not that difficult and do more to change the nature of the car than any other combination of mods that I have done before.
#47
Moog 5662 fronts with new OE isolator puts the car at 26 3/4.
Moog 5665 rears with radiator hose and approx. 3/4 of a coil cut puts the car at 27 1/4.
EDIT: After a few days of driving, the rear has settled at 27 (Much to my surprise).
The combo provides a slight rake, but I'm content at the moment.
JamesC
#48
I "believe" that 27 1/2" is stock ride height. That said, here's the final for me:
JamesC
JamesC
#49
Car: 87 GTA
I like the rears SLIGHTLY higher than the front, but only by 1" or 2", there abouts.
