ARC k-member, control arms, and coilovers arrived
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Just picked up my front suspension parts today, looking good so far. I bought everything from http://www.americanracecomponents.com/. I won't be able to install everything quite yet, as I plan to order new struts, steering, and upgrade to LS1 brakes. Basically I plan to replace/upgrade the entire front steering/suspension all in one pass.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: ARC k-member, control arms, and coilovers arrived
That looks pretty good, a tubular k-member with some more beef to it. Tell us how it all goes together, I wonder if other a-arms are compatible..
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
thats not a bad deal.
if its no trouble, could you get a weight on the k member?
also, since i dont like their a arms, do the stock ones fit in there?
if so, then other a arms can be used
Car: 1988 GTA
Engine: 5.0 TPI
I'm guessing that other a-arms would work. Their k-members do require coilovers though, since they don't have spring perches. I'd guess the weight of the k-member and a-arms at about 30 to 40 pounds, I don't have a scale to weigh it though.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Well, if it works as good as it looks you should have a great handling car! Just the weight reduction should help....will you change over to rack and pinion steering too???
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
its a shame it doesnt came with spring perches, i actually like that k-member, seems to be well braced in important spots.
OP, did you even install this, how did it fit?
Hotrodboba400
12-10-2019 07:07 PM
