pitman arms..cant find them
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
my pitmanarm needs replacement. i called all the local autoparts stores and they say that their diagram of my camaro doesnt show a pitman arm. I call BS. does anyone know where to get a new one. and how much they would be?
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: pitman arms..cant find them
I'm guessing you mean you're looking for an idler arm. There is nothing to wear on a pitman arm unless it just completely broke.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pitman arm is attached to the steering box. Idler arm is mounted on the other side of the car.
Pitman arm is a non wearable item. Only time it needs to be replaced is if it's damaged (bent or broken) in an accident. It's just a chunk of steel.
Who keeps telling all these third gen owners that they have a worn out pitman arm?
haha, thats waht everyoen is saying. that pitman arms dont wear. bs, my tech teacher shown me how to check it. he was checking my wheels like you would do for ball joints for inspections. my wheels moved to much. we looked under my car and the pitman arm. it was coming out of the steering box. is movingwhile i am moving the wheel. also i have like a 2 inch play in my steering wheel.
if i do this should i do pitman and idler arm's?
Car: check
Engine: check
Transmission: check
You need to find another tech teacher.
Think about this statement from your first post: "I called all the local autoparts stores and they say that their diagram of my camaro doesnt show a pitman arm."
Why do you think they don't have them listed?
Because there is no wear joint in the 3rd gen pitman arm. It is a piece of metal with a tapered hole at each end. To get another one hit the classifieds here or hit a junk yard.
Otherwise replace the center link, idler arm, the 4 tie-rod ends, and the rag joint.
RBob.
RBob.
yeah i do want a nother tech teacher. ill search on the classifieds on here and see if anyone has one.
thank you rBob
thank you rBob
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I have an extra one, but I can pretty much guarantee you don't need it. There is nothing to wear (as others have said). What does wear, especially on cars with fat tires, is the pitman shaft bearing in the steering box. For most people that would mean a rebuilt box.
Car: 87 IROC L98
They only way it could wear is if it wasn't tightened onto the steering box which I could highly doubt. You always need a puller to take it off.
If the center link tapered end wasn't tight into the other end, maybe the hole would become elongated. I doubt that would happen either. The steering would be so loose the car would be undriveable.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
My wheels do the same thing, lots of play but tight tie rods and center link. My steering box is hosed so I am shopping for a new one
MikkoV
09-09-2015 04:25 PM
