Moser 12 bolt sway bar problem
I have a 1982 Trans Am and recently installed a Moser 12 bolt with the aluminum support cover. Now my sway bar won't fit. I tried the Spohn aftermarker sway bar relocation kit which was basically a 3" pipe clamp with the other part to clamp onto the 3" axle shafts of the rearend. Has anyone else ran into this problem and if so, what was the solution.
Thanks!
Thanks!
1 Post
Car: 1985 Pontiac Trans Am
Re: Moser 12 bolt sway bar problem
Sure wish UMI made sway bars..Anyways if I read this right U are using the stock sway bar. I just installed a 1" rear spohn bar. with the aftermarket kit u refer 2.The kit drops the bar lower and provides longer end links 2 allow clearance for the after market rear support covers.Definitly get some pics up.But the problem may be the stock sway bar.Did u use the longer links?
The problem is the stock sway bar is too small. It doesn't fit around the support cover. The guys at Spohn tell me they have one that'll work. I've ordered it and will update this post when I've gotten it and had time to try and install it. Meanwhile, my left rear shock has ripped out about a 3" diameter piece of sheet metal from the top of the shock tower or whatever it's called and that's going to be a **** to fix.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
the sway bar should have a drop in the middle to clear the rear, are you sure you dont have it on upsidedown? i've seen it done.
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
I know this is an old thread but I know have a similar issue,
Moser rear, Spohn sway bar - sway bar is hitting my rear shocks need a 1/2" on each side to be clear
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
red90IROCls1
08-25-2015 06:56 AM
