rear end unlevel
Car: 88 Firebird
Engine: 406 small block
Axle/Gears: stock posi
rear end unlevel
i just put new coils and shocks under the rear of my 88 bird. now the pass side sits about an inch higher than the drivers. i switched springs and shocks from side to side still same result. anybody had this problem or any advice on the fix?
Car: 88 Firebird
Re: rear end unlevel
yea both are in and both coils set in the insulators all the way. someone told me that the position of the end of the coil at the top will affect ride height?
Car: 87 GTA
It sounds like one of yours is not properly indexed & sitting correctly.
Car: 88 Firebird
the coil is all the way in the step. will it make a difference if that step is located to the front or rear of the car?
Car: 87 GTA
Not that I know of. It was used as a dampner of noise & to provide a level seating surface, AFAIK.
I guess you could try to index them both to the same point & see if that changes anything. :dunno:
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
