rag joint elimination? I'm fabbing up my own flaming river quality setup
1 Post
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
heres the lower joint, the stainless 3/4 dd shaft and upper joint are still in the mail. I'll take more pics when complete, but this complete will run maybe 150 total in parts all polished stainless
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: rag joint elimination? I'm fabbing up my own flaming river quality setup
Keep us updated & post some pictures & part numbers.
I want to do this to my car when I bring it back out in the spring. My factory upper universal has some play in it & I was looking into building one like this as well.
1 Post
Car: 82 Trans Am
Transmission: t-56
I ended up starting a similar post in fabrication that has the links to the same items I am using on ebay. check it out
Guest
Posts: n/a
I did this a few years back. Tried the aluminum disk "ragjoint eliminator" and had bind as a result so I went to Borgeson joints. The shaft looked nice going in but has now rusted.
http://www.cardomain.com/member_page...0150_large.jpg
I painted the one in my truck to about 1/2" before it telescoped, and I keep that last 1/2" greased.
1 Post
Car: 82 Trans Am
Transmission: t-56
I painted mine right before i installed it.That was some 5-6 years ago.Just regular ol spray can & it still has'nt peeled or burned off.There is no issue with paint on the u-joints either.Since they have a seal to keep out debris & keep in grease.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I bought an astro van shaft years ago to do this but never got to it due to no welder. Now that I have a welder, cant seem to find the shaft I bought. Is this setup going to be mostly bolt together?
1 Post
Car: 82 Trans Am
Transmission: t-56
in fact the last of the parts arrived today and I will be installing it tonight and will post pics
I welded my U-joints to the 3rd gen steering shaft.The shaft was cut about 3/4 inch.The box end U-joint slips on, but the firewall end is pressed to the shaft.They were both welded to the shaft at the ends.Its a telescoping shaft.So it will collapse if ever there were a front collision.The part that bolts on are the ends.To the box & steering column on the firewall.
Engine: 350 S-TPI
84, I see how you got confused. I knew the astro van shaft needed to be welded. I was talking about this new setup the guy posted. Sorry.
So 100% bolt, sweet. Please post some pics.
1 Post
Car: 82 Trans Am
Transmission: t-56
bought a 36" long shaft so i just took it down to the shop and cut it down on the lathe.
I'll post pics tonight of the parts assembled and maybe on the car if I feel ambitious
1 Post
Car: 82 Trans Am
Transmission: t-56
1 Post
Car: 82 Trans Am
Transmission: t-56
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I'll admit I don't know jack about steering. But what is the other bar for in your pics of the parts? Let us know how it works on the street.
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I made a similar shaft last year using flaming river parts, too.
Guest
Posts: n/a
The joints I used are in fact also from Flaming River and were ALSO stainless steel. Look at the rust spots on the swivel caps. You are still going to get it, some parts are only strong in mild steel for safety. Mine looked that nice going in just like the post directly above this pictured.
