Can I cut down the spring isolator?
Old 01-03-2009 | 11:11 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm not happy with how high the back of my car sits. Ever since I installed the 4th gen spring isolators with the Pro-kit springs, I have way to much open space between my tire and fender. Now I know I can go back to my stock isolators, but they are kind of trashy looking... and I know no one makes stock 3rd gen isolators because I was looking for weeks before I caved in and got the 4th gen pieces.
Now, I don't like the idea of having no isolator between the spring and the body, so I was wondering... since the 4thgen ones just seem to have more rubber between were the spring sits and where it touches the body, would it be possible to trim them down? By trim I mean like take a knife/saw and actually cut a chunk off them. I realize I will have to keep the same curve on the inside because of how it sits against the spring seat on the body. Would it work better on a lathe, or would the rubber deform and it would be counterproductive? Has anyone tried this?
Input appreciated,
Mike
Old 01-03-2009 | 11:21 PM
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
Re: Can I cut down the spring isolator?
you can do whats called the "hose mod" pull the spring set down remove the isolators then get some heavy duty 5/8 heater hose slide onto the coil about 5" or less then reinstal springs.....my car dropped 3/4"- a full 1" and of course there is no difference in the ride but my fat bootied 4th gen goes around corners waaaay better.
Old 01-04-2009 | 07:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No such luck here. Maybe a 1/2" tops.
JamesC
Old 01-04-2009 | 12:56 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
x2. I do this when doing any spring swap. Prob. about 1/2 inch more drop.
Old 01-04-2009 | 01:21 PM
Car: 90 RS
Engine: 5.0 TBI
i did say my car dropped 3/4 - 1" just for reference.
Old 01-04-2009 | 02:34 PM
Car: 1987 IROC-Z
Transmission: TH350
How would this work though? The spring wouldn't sit even in its seat on the body because the top isn't flat (or is it?.. don't remember). So do I just find a rubber hose that fits snug around the coils of the spring and only do the first coil or coil and a half? Will it make the car react differently to bumps or the turns when I race due to the lack of cushion that the current isolator provides? Will it become more twitchy because of the quicker responses to body roll?
Cool, 1/2"-1" lower is going to look a ton better then where it is currently.
Mike
Old 01-04-2009 | 02:42 PM
JERRYWHO's Avatar
Originally Posted by racing geek
I'm not happy with how high the back of my car sits. Ever since I installed the Pro-kit springs. Input appreciated,
Mike
The same for me, the rear was way to high with the pro-kit.
What I did yesterday was cut the spring isolators on a band saw and then reground the shape with a 4 inch body grinder with a 36 grit disk, this will only get you 3/8 and I still need more.
Jerry
Old 01-04-2009 | 03:12 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I just took out my isolators. I'm lazy.
Old 01-04-2009 | 03:27 PM
Car: 1987 IROC-Z
Transmission: TH350
I would do that too, but I'm afraid of metal on metal contact.
I'm thinking I'll try the hose idea when I get my car out in the spring. Then again I may end up keeping my wheels when I install a LS1 rear so maybe I will need the extra height so it wont rub as much.
Oh the dilemma,
Mike
Old 01-04-2009 | 04:53 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I run mine when I have the stock 16s, but not when I have on the 17s. I've not noticed any adverse affects. I have been planning to do the heater hose mod at some point, though. My front isolators were so shot from the mechanic installing the springs up-side-down when I first bought them that I just left them out. Probably need to do it up there too.
Old 01-05-2009 | 01:03 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Are the 3rd gens gone from the aftermarket??? Aftermarkets were easy to get a few (or more) years ago.
Old 01-05-2009 | 03:18 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Yeah, I have tried the stock, 4th gen, and the hose method, with a Prokit. I ended up putting the stock isolators back in. Who cares how they look, nobody is gonna see them.
gta892000
08-11-2019 12:16 PM
crzycamaro86
09-12-2015 06:51 PM
Thornburg
09-12-2015 11:11 AM
lakeffect2
09-07-2015 04:52 PM
FormulasOnly
09-06-2015 11:42 AM
