Help please can i put 255/60/15 tires to 10 inch rim?
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Can i put this tires
http://store.summitracing.com/partde...0&autoview=sku
to rims like that
http://store.summitracing.com/partde...5&autoview=sku
to rims like that
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Help please can i put 255/60/15 tires to 10 inch rim?
I bet no.
Check the "specs" page on sites like Tire Rack. com.
There will be a wheel width range column for each tire. My guess is a 255 will probably fit a 7.5 to 9, but check it out for yourself.
Enjoy.
Enjoy.
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
those tires are a little skinny for that rim but i think they would work without an issue.... u could fit up to a 295 if you want but a 275 would be perfect
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
iagree:
I currently run 275/60/15 rear tires on 10" wide rims with 5.5" back spacing. I think wider tires would look better but I'm stuck with these till they are worn out.
colton_carlson
03-08-2019 12:21 PM
