Suspension issues
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
Suspension issues
If anyone has some advice I would appreciate it. Alright the car to the left that you see has 171 th. on it . I am fixin to get a set koni reds all the way around, but can I just replace my front strut mount bearing or do I need a new set ? And if the springs should be replaced as well, which ones should I go with?
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Suspension issues
I'd reccomend getting an aftermarket kit. They are more durable than the stock replacements and do a better job. The springs choice is up to you. Do you want to lower it or just replace them?
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
Well, I have found out today by looking at my upper strut mount that I cannot replace bearing.
So I have found acdelco replacement mounts for two shipped, 160.00 .
And Are those j&m caster/camber plates (with spherical bearing) needed for street/strip car ?
Im fine with ground height with the ground effects . . .
So ill prob just figure out which mounts to get with the konis, cause I do know my front left mount is knocking up in down, so I will replace both.
I am guessing that the SFC from UMI for 199.00 are about my best bet considering im going with longtubes, x-pipe, and duals (hence the reason I cannot lower any more)
Car: 1991 RS Camaro
If it's going to be a street, strip car, the Delco pieces would work fine. Just don't get stuff from Advance/Auto Zone. Mine were poo. Either the Spohn or UMI will be good. I think that the UMI design may be stronger after alot of reading.
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
Yea, thats what Ive been hearing. Strano perf. and Umi are 199.00 for SFC , thats prob what I will go with . Thanks alot man. . .
We also have sets available and ready to ship! Not to mention ours are on sale for $149.95!
SFC008 is designed for cars with full length headers and exhaust systems that run inside the frame rails.
SFC009 is designed for cars equipped with the OE manifolds or shorty headers with OE exhaust or OE type exhaust that runs on the passenger side, outboard the subframe.
Just another option for you
Also click on the link in my sig for other 3rd Gen items on sale till dec 24th!
Car: 87 Iroc Z-28
Engine: 350 tpi
Axle/Gears: 3:27
Well im fixin to get koni reds, front and rear. I didnt see any caster/camber plates on BMR, is there any better mounts than oem/acdelco for under 170.00 shipped to nc?
Yes you can unless it's some really odd system.
