Would this be a decent setup for my camaro??
Old 11-09-2008 | 07:13 PM
91camaro372's Avatar
Car: 91 Camaro RS
Engine: 3.1L v6
Axle/Gears: 2.73(for now) posi disc from 95 Z28
I am going to be replacing different things in my suspension over the next couple months. I have a 91 camaro RS with a 3.1l v6. Heres what i'm planning on doing first.
Springs- Summit lowering springs
front shocks- KYB GR2
Rear shocks- KYB Gas-a-Just
Bushings- Energy suspension hyperflex kit
Panhard bar- Spohn Adjustable w/poly bushings
The shocks were the only thing I wasnt sure about but they seem to be the nicest ones I could get for around that price. I'm only 14 so I dont have a lot of cash so pretty much all my money is going into this car. Also will I need to get Rear LCA relocation brackets? If you have any suggestions can you let me know.
Old 11-09-2008 | 08:36 PM
irocboy8292's Avatar
Car: 1986 Camaro Z-28
Engine: 3970010--5.?l
Re: Would this be a decent setup for my camaro??
you wont need to get the LCA brakets unless you want all the traction you could possibly need.. not something you NEED.. maybe something you might WANT lol
Old 11-09-2008 | 09:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
you dont "need" the control arm relocation brackets, but they are a good idea if you are lowering the car, and you seem to be lowering the car, so they are a good idea.
Also keep in mine, the car has some age to it, the springs are probably sagging. Dont be surprised of the springs dont lower the car.
I would pass on the bushing kit, it has a lot of parts you will never use, and the rest require a lot of work to change.
I might suggest that if you can swing it, just buy a new trans mount, rubber or poly, and a set of rear control arms to match the panhard bar, i would also suggest you get the panhard adjustable so you can center the rear after you lower the car.
your shock selection if fine.
Old 11-10-2008 | 06:15 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I'd go over the car before buying any new parts and replace the bushings and stuff (sway bar bushings, endlinks, ball joints, tie rod ends, etc) in the car that need replacing.
Make sure the springs are V6 springs. The V8 springs will most likely lift the front of the car and be too stiff. I'd replace the LCAs before the PHB if it were me.
Old 11-10-2008 | 01:34 PM
Car: 91 Camaro RS
Engine: 3.1L v6
I was wondering about the springs also so I called summit and they said that the springs would work fine with the v6 or the v8 and there is barely andy difference. So I eventually want all my suspension done so it would be better to skip the poly kit for now? The springs are definatly sagging right now so i'm expecting it to stay around the same or gain a little hight with the new springs. From research it seems that sense i'm going with lowering springs I need the Adjustable panhard bar thats why I had that on the list also. What would the new LCA's do for my handling wise? I will probably go ahead and get the LCA relocation brackets also. Pretty much my suspension is all im going to be working on till spring/summer so i'm hoping to get alot replaced.
Thanks for the feedback
Old 11-10-2008 | 05:34 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
That's really funny that they'd say that.... the difference in between a V6 and V8 is a few hundred pounds if I recall. The front of the car will set higher if you use V8 springs. That's why GM has different springs for the V6, V8, the convertables, etc. I'm not saying they won't work, but there is a difference in the needs of a V6 front spring and V8 front spring. If you actually want to lower the car, you'll need to get springs with rates and heigh to match the weight of the car. One option is to research what you'll need an order a set from SSS or ERS (Eibach Race Springs). Those are around $60-70 a corner. Another is to buy a set of weight jacks so that you can adjust the ride height to suit you. That kit is ~$460.
The PHB is a good idea, but not required. The difference in the offset when you lower the car is pretty small and it's most important to clear wide wheels. The LCAs (with the correct bushings) will help the handling of the car. The stock arms flex too much. But, if you run poly bushings, the suspension won't be allowed to function properly.
The biggest gains in handling in a street car are to be made in the tires and shocks department. I know it sounds simplistic, but the tires are what keep you attached to the ground and the shocks are what control the suspension. Everything else is just icing on the cake.
Replacing the bushings is a good idea, but buying a whole kit like that isn't necessarily a good one unless you know you'll need everything in it. I'd start by checking your front steering, and front suspension mounting points and replace what needs to be replaced up there. You can expect ball joints, inner and outer tie rod ends, a-arm bushings, and the like. Polyurathane is good in most situations, but there are better options for the a-arms (such as what I mention below). The sway bar bushings and endlinks work well if replaced with poly, but make sure you don't bet bushings for your current bars if you want to upgrade the sway bars later. No need to buy bushings twice. Endlinks will work with any sized bar. I go into why not to use poly bushings in the LCAs in the bottom of the quote.
I did this write up on Z28.com. It might help you some.
Originally Posted by Me
Section 1: Lowering a F-Body The Right Way
If you are wanting to lower you car, there are several things you have to take into consideration.
The first thing that needs to be done (especially on the older cars) is to check the bushings for wear and tear and replace as needed. This includes inner and outer tie rod ends, ball joints, sway bar bushings, control arm bushings, etc. This isn't an absolute necessity, but starting to modify a car with worn components.... This is especially true if you are going to build the car to turn (as in Section 2).
When selecting bushings, sticking polyurathane everywhere isn't really the best choice. While polyurathane is great in sway bars, it looses it's shine in places like the LCAs. (See FootNote 1) Rod ends work well in the LCAs, but to some they are too harsh. I have a set of LCAs built from parts ordered from the circle track suppliers. Heavy duty rubber bushing on the body and a rod end on the axle. A-arms don't see the same twisting forces that the LCAs undergo, so polyurathane is pretty good here. but the best option (or so I've been told) are the Del-A-Lums offered by Global West. Polyurathane also works in the pan hard bar. I prefer a combo ended set up for the PHB, as well. I use NAPA parts for the steering linkage bushings (tie rods, ball joints, etc). Moog also makes quality replacement parts. A word of caution, polyurathane anywhere will squeak more than rubber, but it's not really enough to be a bother as long as your in the car.
When replacing springs, GET SHOCKS WITH YOUR SPRINGS. If you lower a car, it does more than just make it look cool. Lowering springs normally not only lower the car (causing the shocks to set at a place they are not designed to do) but are have a higher spring rate (stiffer). Both of these related occurances cause stock or replacment shocks (Auto Zone, Advance, NAPA, etc) to wear out much faster. This isn't only bad for handling, it's literally dangerous after prolonged periods; it causes the vehicle to be harder to control at speed and can increase braking distance. Shocks to consider are KONIs, Re-valved Bilsteins; these are somewhat common and more expensive names. But, if you don't want to spend that kinda money (keep the stock springs), there are other brands that will work.
In addition, when you lower a car, it affects your suspension geometry. The basic fix is LCA (lower control arm) relocation brackets. They will allow you set the angle of the LCAs back to stock after lowering. An adjustable PHB (panhard bar) is a good idea, because lowering a car without one will cause the rear alxe to set off center. It's not very noticable nor neccesary, but it is a good idea.
Section 2: Making an F-Body Handle....Better
For those of you looking to do more than just get rid of wheel gap (though, nothing wrong with that)
Best first mods (after replacing worn out bushings, etc):
1. Tires: Good ones = MONEY I've heard good things about GoodYear Eagle F1 GS-D3s, Falken RT-615 and Kumho MXs (although, MXs aren't a very good wet traction option). My advice is to get onto frrax.com or other auto-x/road race enthusiast site and do some reading. Purchase the best tire you can afford with the characteristics you want. Listen to people with experience, not what your friend (unless they really do know their stuff) tells you or what the tires salesman says.
2. Shocks: (again, money) KONIs or if you don't have the money (or want to spend it) revalved Bilsteins (to match your spring of choice). I've heard that the high end Tokicos are a decent as are the high end KYBs. But, in my opinion are budget shocks. I've read that neither has dampening qualities to handle more than spirited back roading. Also, they won't live as long as the Revavles or the KONIs unless you are using factory or factory replacement springs.
3. Springs: Lower isn't better unless you have the spring rates to back it up (why 3rdGen SportLines aren't that good). While it's true that a lower center of gravity helps your car's handling, setting low to the ground on soft springs is a bad thing. It can let you hit the bump stops (which have a much higher 'spring rate' than the springs) and this can cause snap over/under steer. The combination of the right spring rate and ride height coupled with the correct shocks makes the biggest difference in a car (other than tires).
4. Sway Bars: With sway bars, the biggest you can get isn't necessarily the best; finding a balanced set of bars is very important (for example, my rear bar is too big and causes the car to over-steer instead of under-steer, especially under throttle). But, you'll also need to take into consideration how the spring rates as well as the valving of your shocks interact with your sway bars. For example - a large rear bar may work well with the factory springs, but when you install stiffer springs you notice the car behaving differently and wanting to oversteer. This can be fixed either by softening the settings on your shocks (if adjustable) or moving to a smaller rear bar. Similar rules apply to the front.
An agressive street allignment (usually overlooked) is in there somewhere...not sure where to list it, but it is VERY important. I had my car alligned more aggressively than stock and imediatly noticed a difference in the feeling/stability of the corning of the car. I can link a listing of what is reccomended if you are interested.
Some people won't agree with that listing/order, but it's what the auto crossers and road course racers recommend when your first getting into it. All the other stuff (LCAs, PHB, relocation brackets, SFCs, etc) helps of course, but you will see the most bang for the buck with that list... just expect to lot of bucks haha. You will also need to consider stiffening the frame, especially if the car is a 3rd gen. SFCs are a good option, but don't offer the complete rigidity of a 6 or 8 point cage. However, the drawbacks to a cage are obvious.
Section 3:$$What You Can Expect to Spend$$
To give you an estimate, I have the following in my suspension:
KONIs around............................................ ... $750
Pro-Kit: .................................................. .....$245
Camber/caster plates .....................................$149
Wonder bar .................................................. $70
LCAs around .................................................$200
PHB.............................................................$160
rear sway bar ...............................................$160
front sway bar I used
from my parts car...........................................$150
brake pads were about ...................................$110-120
(Not really a part of the suspension, but if you are going to be going faster, you need to be able to stop faster and the Zone won't cut it)
SFCs + installation .........................................$340
Total ~ $2200
FootNotes
1. In the LCAs, the polyurathane can create bind in hard cornering. This bind is caused by the LCAs not being able to work as they are designed to. As the rear suspension is designed, the rear of the car moves over the rear axle (imagine the axle as fixed and the body as mobile). When the car enters the turn, the body tries to move to the outside of the turn due to momentum, while the axle tries to remain in place (you hope). Now, if taken from a helicopter view, this motion must have some affects on the suspension linkages. The most appearent is in the LCAs. As the body moves over the axle, the LCAs are put into stress. The factory bushings allowed for this by flexxing and allowing the energy of the movement to absorbed and dissapated easily. Polyurathane is stiffer than the rubber, and doesn't allow this disapation so nicely. They can cause the bind I mentioned and snap back into their original postion. I've had this happen to me on several occasions, and it's interesting to say the least
Old 11-10-2008 | 10:22 PM
Car: 91 Camaro RS
Engine: 3.1L v6
That is funny that they told me that. Summits usually really good with tech related things. I dont want to lower the car a lot. The main reason I would like to go with v8 springs right now is that either next summer i'm swapping in a 305 or later on when the v6 dies i'm going to put in atleast a 350 (would go ahead and swap in a 350 but my dad said I cant have a 350 for my first car lol) So do you think the car would stay at about the stock hight with the summit lowering springs with the v6 in there and then eventually when I get a v8 it would be lowered an inch? The main thing is that I dont have a lot of money so the kit you were talking about is $460 versus the springs are only $160. Thanks also for the link to your other thread it was very helpful. I'll probably go through and examine the front/rear and decide what needs to be replaced in the next couple of days.
Old 11-11-2008 | 09:26 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I understand not having much money. I've worked on my car piece-meal for the last four years. I've been wanting that kit for a couple of years but haven't been able to get it either.
I'd say if you use the V8 springs, the car would either sit at stock height or a little above, but I can't be sure. If you install the V8, it would lower the car to near where it's supposed to be according to the advertising.
Old 11-11-2008 | 03:49 PM
Car: 91 Camaro RS
Engine: 3.1L v6
Alright thanks. They should be perfect then for me. I should be getting some cash soon if I can get my bros rx7 sold. I will probably go ahead and start replacing bushings after I get the money. Another question. What would be the benefit of putting in a poly trany mount? Besides it being much stronger are there any other benefits?
Terrell351
06-13-2021 01:13 PM
evilstuie
01-09-2020 08:29 PM
Eric-86sc
04-03-2016 03:52 PM
redmaroz
08-16-2015 11:40 PM
Street Lethal
08-13-2015 08:28 PM
Quick Reply: Would this be a decent setup for my camaro??
